Arduino Uno R3 Driver Issue: Program Only Sees COM1 Port, Unable to Install Manually
XSPACE18 17484 2
  • #1 16570029
    XSPACE18
    I have a problem with Arduino uno r3. I connect the board to the computer and I have a problem installing the driver. I tried to manually install the drivers but it still doesn't work, and the program only sees com1 port all the time.
    Install missing drivers by hardware ID first
    #2 16570348
    kiss39
    Help: 397
    Rate: 636
    First install all missing (yellow exclamation point) drivers - after hardware identification.
    e.g. yes
    Device Manager> Data device with exclamation mark> PM and expand you choose "Properties" >> Details> Hardware IDs: PCI \ VEN_1002 & DEV_6811 & SUBSYS_20151682 & REV_81
    Looking for a missing driver by ID in Google: e.g. PCI \ VEN_1002 & DEV_6811 & SUBSYS_20151682 & REV_81
    Added after 12 [minutes]:
    You will have drivers for Arduino, e.g. in the c: / Program Files (x86) directory. Arduino> drivers - select drivers with the extension * .inf)
    Added after 5 [minutes]:
    Here is a step-by-step guide on how to install IDE Drivers and Arduino
    Arduino Course - # 1 - Arduino basics and environment
  • #3 16570770
    XSPACE18
    Thank you for your help
