Climatronic Golf IV Disconnects the compressor when it heats up.
pisior1987 9738 2
  • #1 16572183
    pisior1987
    Help: 12
    Rate: 351
    Golf IV 1.9 TDI 90KM.
    Problem as in the topic, on warm engine it disconnects the compressor.
    I concluded that it disconnects the "A/C overheat protection switch". I have marked on the diagrams:
    Climatronic Golf IV Disconnects the compressor when it heats up. Climatronic Golf IV Disconnects the compressor when it heats up. .
    What is it and where is it located?
  • #2 16572190
    ptr92
    Level 19  
    Help: 27
    Rate: 248
    The thermal fuse is in the compressor coil, but I don't know if that's the one in question.
    I think the problem with you is that the fan is not cooling the refrigerant, the pressure builds up and disconnects the compressor.
  • #3 16572201
    pisior1987
    Help: 12
    Rate: 351
    As it would not cool the refrigerant, the pressure will rise and then it will disconnect the pressure sensor. The circuit on the sensor closes. Further there is a problem between the sensor and the fan (compressor) controller. The fans are working. The pressure on high does not exceed 15 bar.
    Added after 2 [hours] 30 [minutes]: .
    This is sensor F163 - air conditioner thermal switch.
    No. 9 in the photo. Mine was damaged.
