Golf 4 1.6 SR Climatronic Issue: Engine Fails to Reach 90°C, New Thermostat & Sensor
Boskixd38 6741 10
Why won’t my Golf 4 1.6 SR with Climatronic reach 90°C even after replacing the thermostat and coolant sensor, especially when both cooling fans run with the A/C off?
If both cooling fans run all the time with the A/C off, the engine can be overcooled and may never reach 90°C; that fan behavior should be checked first [#17141925] One reply also warns that the thermostat may still be the problem if only the cartridge was replaced and not the complete thermostat assembly [#17142306] Another advises checking the coolant-temperature values in diagnostics instead of replacing the sensor blindly, because a difference of about 5–8°C between the readings is enough to justify sensor replacement [#17142571]
  • #1 17141850
    Boskixd38
    Hello . I have a golf 1.6 sr. Cilmatronic
    The problem is that the engine does not reach the temperature of 90 °, but is still below, I will add that the thermostat has been replaced with a new one and the sensor is functional, and both fans run from engine cooling and air conditioning, even if the kilma is not turned on. Please help ;)
  • #2 17141902
    przemek25l
    Help: 124
    Rate: 372
    Any diagnostics done?
    What exactly is the temperature when stationary and while driving?
    What company was the thermostat founded.
  • #3 17141925
    Ireneo
    Help: 747
    Rate: 2469
    ... and both fans work from engine cooling and air conditioning, even if the kilma is not turned on ...
    How many fans do you have? There are two and both are air-conditioning and cooling at the same time. If they turn without air-conditioning, the engine will not reach the temperature.
  • #4 17141930
    rafal24821
    Below is how much? Have you checked this new thermostat?
  • #5 17142208
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    When it goes to a standstill and drops while driving, you still have a damaged thermostat.
  • #6 17142245
    triakw
    Help: 22
    Rate: 57
    I support my friend, replace the thermostat, preferably with the original one. Good luck.
  • #7 17142298
    Boskixd38
    The thermostat has been replaced with the original one, so it cannot be a thermostat
  • #8 17142306
    Help: 1405
    Rate: 6430
    Do not be wise because you have failed on a trivial topic, if it is as I write, you still have a thermostat released, because you probably replaced the cartridge itself, not the entire thermostat.
  • #9 17142377
    Boskixd38
    All thermostat replaced.
    Added after 23 [minutes]:
    Maybe replacing the sensor will help? because the sensor was only cleaned
  • #10 17142571
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Instead of replacing a sensor that works, connect it to diagnostics - in the parameters you can see how both sensors work / a difference of +/- 5-8 degrees qualifies for replacement.
  • #11 17142662
    Help: 1405
    Rate: 6430
    Seriously? Give a link to a photo of what you had, and enter the exact engine code you have.
The discussion revolves around a Volkswagen Golf 4 1.6 SR with a Climatronic system that fails to reach the optimal engine temperature of 90°C, despite having a new thermostat and a functional sensor. Participants inquire about diagnostic tests, the specifics of the thermostat replacement, and the operation of the cooling fans. Suggestions include verifying the thermostat's installation, considering the replacement of the temperature sensor, and using diagnostic tools to assess sensor performance. The consensus indicates that the thermostat may still be faulty or improperly installed, and that diagnostics could provide further insights into the issue.
