Golf IV Air Conditioning Shuts Off in Hot Weather, No Errors on VAG Scanner
fifi07 52276 12
Why does my Golf IV air conditioning switch off after about 10 minutes in hot weather and then come back on after cooling down, with no VAG error codes?
The most likely cause is a dirty condenser/radiator or a cooling-fan problem that makes the A/C cut out when it gets hot. Check that the condenser in front of the radiator is clean and that the fins are not bent; also verify the fan, its fuse, relay, sensor, and motor, because if the fan does not run it can cause this behavior [#6540955][#6540970][#6541057] In the reported case, washing the radiator/condenser with pressurized water solved the problem and the A/C started working normally again [#6546307]
  • #1 6540393
    fifi07
    Rate: 29
    Hello, I have a Golf IV and I have just noticed that for some time now something is happening with my air conditioning. Namely, the problem is that when the car is cold, i.e. when I leave the garage and it is about and less than 10 degrees Celsius outside, everything works all the time, but when it is hotter outside, the air conditioning works for about 10 minutes and then turns off. Then I go away again for a bit (it's difficult to say how long, as it can vary) and it switches on for a while and then switches off again. And so everything repeats. From what I've noticed, when it's not running the fans don't work and I can't feel the compressor or compressor switching on because there's no slight jerking. And in the same way if I try to switch it on with the button it does not work and the compressor does not switch on. The vag does not show any errors. Has anyone had a similar problem or know where to start checking?
  • #2 6540453
    ptaszek1975
    Level 30  
    Help: 121
    Rate: 444
    I would start by knocking on the gas .
  • #3 6540455
    fifi07
    Rate: 29
    This is what I did in the first place but it didn't help:(
  • #4 6540466
    marek1977
    Help: 204
    Rate: 710
    What is the time between switch-off and switch-on? A few seconds, minutes?
  • #5 6540480
    fifi07
    Rate: 29
    It varies from 10 minutes to half an hour, and if the car is stationary for a while and cools down, it usually always switches on...
  • #6 6540589
    artek10212
    Rate: 14
    Is the air conditioning manual or climatronic ?
  • #7 6540628
    fifi07
    Rate: 29
    Manual ...
  • #8 6540955
    Adam1988
    Help: 49
    Rate: 161
    Probably too much refrigerant or a dirty condenser.
  • #9 6540957
    fifi07
    Rate: 29
    Is there too much refrigerant, i.e. too much gas? Do I clean the condenser myself or do I have to go to a professional and if so, where is it?
  • #10 6540970
    Adam1988
    Help: 49
    Rate: 161
    refrigerant = gas ;) The condenser is before the radiator, clean it and check that the fins are not bent.
    Is the fan on? What is the temperature of the dryer just before it switches off?
  • #11 6541005
    fifi07
    Rate: 29
    The fan doesn't turn on just now.... I will have to look and if I remove the condenser nothing will happen to the factor?
  • #12 6541057
    Adam1988
    Help: 49
    Rate: 161
    If you remove it, refrigerant will escape. Check the fan: fuse, relay, sensor, fan motor.
    If it doesn't turn on, it could be the cause.
    Specify the temperature.
  • #13 6546307
    fifi07
    Rate: 29
    The problem seems to have been solved... The radiator was probably dirty. I washed it with water under pressure and so far everything has calmed down. So please do the same for your radiator and let me know if it works, because there was a lot of dirt in my...
The discussion revolves around an issue with the air conditioning system in a Golf IV, which operates normally in cooler temperatures but shuts off after approximately 10 minutes in hot weather. The user reports no errors on the VAG scanner. Responses suggest potential causes such as excessive refrigerant, a dirty condenser, or a malfunctioning fan. The user later resolves the issue by cleaning the radiator, which had accumulated dirt, leading to improved air conditioning performance.
