Switching Gas Cylinders to Electric Ones for Tailgate Automation: Recommendations?
m.biruta 14118 15
How can I replace a car tailgate’s gas struts with electric actuators, and which actuators should I look for?
You can do it in principle, but it is difficult because electric actuators are usually much wider and larger than standard gas struts, so a truly slim replacement may be hard to find [#16577631][#16580225] Search for “12V electric actuator” and look at factory tailgate actuators used in cars such as the Volvo XC60 and BMW X6 E71 [#16577162][#16588754] The actuator is only one part of the system: you also need an automatic lock, preferably one that pulls the flap tight, plus control integrated with the alarm and an emergency-opening method [#16588958] If there is no room in the strut area, the actuator can be mounted elsewhere and its motion transferred with a Bowden cable/bicycle cable [#16588958] Another possible route mentioned was using hydraulic cylinders with an electric pump, as used in convertibles, but that is not a direct slim gas-strut substitute [#16577832]
  • #1 16573695
    m.biruta
    Rate: 32
    I wanted to earn some extra electric opening and closing the tailgate. I thought that this could be done by replacing the current gas cylinders with electric ones. Has anyone tried to do something like this before? Which actuators would you recommend?
  • #2 16573806
    Heroses
    Help: 71
    Rate: 160
    at least write what kind of car it is. If the mechanics allow, I see no contraindications to do so
  • #3 16576466
    m.biruta
    Rate: 32
    Well, I would try to do that. But which actuators to look for? What do you need to enter in google?
  • #5 16577162
    dizba
    Help: 239
    Rate: 808
    12v electric actuator
  • #7 16577631
    milejow
    Help: 1563
    Rate: 5150
    I have not seen such a thin / slender actuator yet, so that it can fit instead of a gas support, so let go of such ideas.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #8 16577832
    Megawe
    Help: 246
    Rate: 1440
    There are interesting hydraulic cylinders with an electric pump in convertibles.
    I used devices from the convertible to lift the engine in the boat.
  • #9 16580225
    PeCeZu
    Help: 16
    Rate: 32
    If a colleague of m. Birut wants to do, as they have new cars, that the trunk opens completely and closes at the push of a button, it will rather be difficult because these actuators are much wider and larger than standard gas cylinders and maybe a problem with their arrangement in the gutter .
  • #10 16588658
    m.biruta
    Rate: 32
    That is why I am looking for actuators used in machines / automation that are small. I hope they are :)
  • #11 16588754
    robokop
    Help: 1763
    Rate: 6373
    VOLVO XC60, BMW X6 E71 - have electric actuators.
  • #12 16588958
    kortyleski
    Help: 957
    Rate: 3860
    The actuator is one of many details. You still need to change the lock to an automatic machine, preferably with the flap tightening, control associated with the alarm, some dynx for emergency opening. Possible to make, but unfortunately not easy. The actuator can be hidden anywhere and the drive can be moved with a Bowden rod, a popular bicycle rope.
  • #13 17371170
    Brayan10
    As you can see in the video, something like this is possible.
  • #14 17376455
    m.biruta
    Rate: 32
    Here he has long telescopes, unfortunately I have 25cm: = /
  • #15 17703518
    karol2
    Hello, did your colleague manage to replace these actuators with electric ones, or rather resignation?
  • #16 17703545
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    Scabbard in which car you install.
The discussion revolves around the feasibility of replacing gas cylinders with electric actuators for tailgate automation. Participants emphasize the importance of knowing the specific vehicle model, as the mechanics may vary. Recommendations include searching for 12V electric actuators, although concerns are raised about the size and fit of these actuators compared to standard gas supports. Some users mention the use of hydraulic cylinders with electric pumps from convertibles as a potential solution. The conversation also highlights the need for additional components such as automatic locks and control systems for a complete installation. Brands like Volvo and BMW are noted for having electric actuators in their models.
