Honda HRG 465C Petrol Lawn Mower: Damaged Knife Clutch, Metal Balls, Plates, & Engine Shutdown
karol1996 9114 3
  • Damaged blade clutch causing engine seizure
    #1 16574517
    karol1996
    Level 19  
    Help: 34
    Rate: 46
    I have a problem with the mower as in the topic. It's about a damaged knife clutch. While mowing, the engine suddenly stopped, it could not even be turned off.
    Upon closer inspection, it turned out that the clutch was to blame. Metal balls and fragments of bent metal plates with joints fell out of it.
    A plate, which is attached to the mower's body, runs through the center of the clutch.
    Most likely, something has bent and the clutch is rubbing against this sheet.
    After removing the cutter and forcibly turning the motor shaft, the resistance on the shaft decreased significantly, but after approx. 3 turns, the resistance increased again.
    Here are some pictures of the clutch (not my authorship, the clutch on my mower looks the same):
    Honda HRG 465C Petrol Lawn Mower: Damaged Knife Clutch, Metal Balls, Plates, & Engine Shutdown Honda HRG 465C Petrol Lawn Mower: Damaged Knife Clutch, Metal Balls, Plates, & Engine Shutdown Honda HRG 465C Petrol Lawn Mower: Damaged Knife Clutch, Metal Balls, Plates, & Engine Shutdown Honda HRG 465C Petrol Lawn Mower: Damaged Knife Clutch, Metal Balls, Plates, & Engine Shutdown
    Is such a clutch available somewhere, or if not, can it somehow be locked permanently?
    Greetings,
    Charles
  • #2 16574895
  • #3 16574929
    karol1996
    Level 19  
    Help: 34
    Rate: 46
    I know that to be replaced.
    But is it available? And this sheet attached to the body? She is also distorted ...
    Charles
  • #4 16575036
    Heinzek
    Help: 554
    Rate: 494
    search on the website http://www.flamingparts.pl
    Parts for mowers, tractors - clutches
    The first one looks quite similar from above
