Inter Race V35 lawn mower – loud noise, gray/blue smoke, stalls?
Marian2010 66080 13
Why does a nearly new lawn mower start smoking gray-blue, lose power, stall, and then refuse to start?
Most likely the mower has oil or another fuel/air problem in the intake or exhaust, so check the carburetor, muffler, air filter, and oil level first, and verify that only gasoline was poured in [#8047544][#8047407][#8070746] If the mower was ever laid on its side, oil can run through the breather into the carburetor and muffler and cause gray/blue smoke and stalling [#8047407] A dirty sponge air filter can act like an extra choke and make the engine smoke only when the choke is on [#8070746] If those parts are clean and the problem remains, remove the head and inspect the cylinder wall and piston rings, because a scratched cylinder or worn rings were also suggested [#8048475][#8058385]
  • #1 8046498
    Marian2010
    Rate: 16
    I have such a question, what could be the reason why the lawnmower is sooooooiled? I fired it yesterday and she walked normally for a while, until suddenly she started to lose speed and choke until she went out. I waited for a while, I fired on the suction and it started to smoke terribly gray / bluish color. When I released the suction, it choked and went out.
    What could it be? The mower is only almost a year old.
    Oil poured in some Tedex 4T not changed after winter and the mower is hard to define because it has V35 written on the top and Inter Race inscriptions next to the muffler: o
    After the night, it does not want to start at all.
    Added after 59 [minutes]:
    The sticker opposite shows that the mower comes from this factory> http://www.ggp-group.com/wps/wcm/connect/ggp_com/GGP+Group/Product+lines/Walk+behinds/ and is very similar to the one on the photo only differs with the plastic at the top and so it's all the same.
  • #2 8046933
    BenQ38
    Rate: 21
    Hello, maybe at the beginning, clean, or replace the candles
  • #3 8047176
    raceman
    Help: 11
    Rate: 114
    Yeah, for sure it smokes the candles .. Please!
    Most likely it's because of the rings on the piston, take it apart and see.
  • #4 8047219
    matiaudio
    Help: 305
    Rate: 283
    Rings, not sealed simering (could have failed). It is difficult to determine the cause without undressing.
  • #5 8047407
  • #6 8047523
    Marian2010
    Rate: 16
    It is the same mower as in the picture because it is from the same factory, the only difference is the plastic on the top and the engine, all the same.
    I don't know, I have to look for a receipt somewhere because it is probably still under warranty because it was bought less than a year ago. It was not tilted.
    Yesterday she still smoked on the choke and today, when I wanted to check if she smokes, she did not want to catch it at all.
  • #7 8047544
    niutat
    Level 36  
    Help: 288
    Rate: 758
    However, I would check if the carburetor is flooded with oil.
  • #8 8047786
    Marian2010
    Rate: 16
    Carburetor checked, clean, no trace of oil.
    The mower was not tilted, today it is used for the first time after winter. Any hint on what the worn rings might look like and what is the best way to get to them? I've never had a problem like this, so I didn't delve into it.
    Is it that I don't want to fire it too fault rings? I checked the spark and it's fine.
  • #9 8048475
  • #10 8051494
    Marian2010
    Rate: 16
    Compression is good because I checked with my finger and it is strong. I also checked the candles and it's ok.
  • #11 8052226
  • #12 8058385
    raceman
    Help: 11
    Rate: 114
    This is a mower, not a TDI engine. Disassembling it will take you max 20 minutes, which is actually less than writing here and waiting for an answer. We have written what to check, so please kindly check it first. What are there to say. The surface of the cylinder should be perfectly smooth without any scratches. Also the rings. Take photos if you are unsure and post them here.
  • #13 8070000
    stan2300
    Help: 15
    Rate: 147
    gentlemen, think about what you write, a new mower with oil in the crankcase and you write about seizure, if the engine rotates or with worn rings, I suggest reading some technical literature, in these engines, until what I see is a low-valve engine, the pressure fluctuates in around 5 at. head deformation is a new gasket, the force of tightening the head is only 2.8 kgm because the head is made of shasmetal, and it choked because the cylinder is lying and the oil that remained in the cylinder for so long has also penetrated over the piston, so it drowned, if it is some problem is only and certainly in the fuel supply system and I propose to work out an air filter if it is made of a sponge, if it was not done after the season last year, because there may be a reason here. Regards
  • #14 8070746
The discussion revolves around a lawn mower that produces excessive noise and smoke, particularly gray/blue smoke, indicating potential issues with the engine. The user reports that the mower, which is nearly a year old and uses Tedex 4T oil, started losing speed and eventually failed to start after smoking. Responses suggest several possible causes, including worn piston rings, oil seal failure, or flooding of the carburetor. Some participants recommend checking the spark plug, carburetor condition, and inspecting the engine for compression issues. The conversation emphasizes the importance of proper maintenance and troubleshooting steps, including disassembling the engine to inspect the rings and cylinder condition.
