Briggs 675 Engine on LIDER Mower: Oil Found in Air Filter, Reduced Power
Misiek85 56064 22
Why is my Briggs 675 mower engine oiling the air filter and losing power, and what should I check first?
It’s usually not the end of the engine: an oil-soaked air filter on this Briggs 675 most often points to crankcase blow-by or a clogged breather/vent, which can reduce power because the engine no longer gets the correct air mixture [#15797661][#15798839][#15798973] Replace the air filter and check whether the mower was ever run tilted the wrong way, because that can oil the filter too, and an old filter can make the problem worse [#15797414][#15797899] Inspect the crankcase breather/vent passage for clogging; one reply says it is reached by removing the muffler, and the valve should let crankcase air out one way only [#15799153][#15798871] If the filter keeps getting wet, check compression to look for worn rings or valve/guide wear [#15798839][#15797661]
  • #1 15797379
    Misiek85
    Help: 26
    Rate: 541
    Hello, I have a problem with the Briggs 675 engine. It's already season 7 and so far everything has been fine. But today I noticed that the air filter is wet with oil and the engine seems to have 1/3 less power. I would like to add that it does not smoke, it fires properly and has equal speed. Is this the end of this engine or is it enough to regulate etc?
  • #2 15797414
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    It was not tilted "in the wrong direction" sometimes and it did not leak to the filter?
  • #3 15797450
    Misiek85
    Help: 26
    Rate: 541
    He was but 2 months ago and for a while. It was foggy then, but not now. What about the lack of power? The grass is not too high, it is about 15 cm long, and the baskets are 5 cm long, and sometimes it may not be choked to zero, but you can hear that it has little power.
  • #4 15797468
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    As the filter is "oily" and wet with oil, it can have problems with suction and mixture composition and thus weakens. The second thing is how it automatically "blows" with oil, it can also be a problem with blowing the rings to the crankcase and thus blowing oil into the filter ...
  • #5 15797629
    szymek.n
    Help: 5
    Rate: 29
    How could that make any sense? What suction, what oil on the filter? Oil on the filter is a sign of loose valves. Maybe the seals let go, or it is enough to run in the valves, or maybe it is quite trivial to adjust the valve clearance.
  • #6 15797661
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    And this is the oil on the filter:
    Misiek85 wrote:
    It's already the 7th season and so far everything has been ok. But today I noticed that the air filter is wet with oil and the engine seems to have 1/3 less power.
    And it has and it has a lot, the air filter is connected by a pipe to the crankcase, and when the engine gets "blows" to the crankcase due to wear, the entire filter gets wet with oil and then the engine sucks too much fuel instead of sucking air. I'm not saying you're wrong with the valves, but it's worth checking everything out. I know this from my own experience with an old lawn mower.
  • #7 15797847
    Misiek85
    Help: 26
    Rate: 541
    I understand. What about the pneumothorax valve? I read that it may also be the reason. Where to look for it and how to check if it is ok?
  • #8 15797899
  • #9 15798192
    Misiek85
    Help: 26
    Rate: 541
    I try to change the oil and filter every season. Oh, there was a mesh with a sponge the size of a filter under the filter flap. I took it off a long time ago. Is it okay? What about engine power? You can somehow check if it has the right one, if not, some kind of regulation.
  • #10 15798839
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    This can only be checked by the compression pressure.
    There is probably no such thing, the crankcase is connected to the filter housing and all oil vapors and other "garbage" from the crankcase are directed to the air filter and through the carburetor back to the cylinder, but it is fine if there is no fumes, too much oil. if there is too much of it, you have to look for the cause.
    What part do you write about "such a mesh with a sponge the size of a filter", I do not know what it can be.
    In my case, there is a plate in the filter housing that covers this outlet of the tube / vapors that the crankcase vapors are directed to this plate, they must reflect on it and come out through gaps around this plate, oil droplets that can be there and if there were any they collect too much on this plate and drip down the filter housing and just fly out. until there are too many of them, the air filter has no right to oil.
  • #11 15798871
  • #12 15798892
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Rycho T wrote:
    There is a pneumothorax valve
    It may be, but I don't know what it looks like and where it is, my knowledge is only knowledge from my own experience and my own practice. I do not do it "professionally" and so "deep" I did not penetrate the construction of engines, but I can fix the whole neighborhood of my buddies as soon as the mower starts to "fix" it runs and "help".
  • #13 15798897
  • #14 15798904
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Rycho T wrote:
    How do you fix such basic matters you don't know?
    Somehow I manage, I have a technical sense and I can handle every mechanic, but maybe I have come across it, but I don't know that it is called "pneumothorax valve" ... :oops:
  • #15 15798973
  • #16 15799144
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1133
    Rycho T wrote:
    If this hole in the pneumothorax becomes clogged, it can hit the filter quite well with oil.
    A similar hole in a similar engine (not the same as in the photo, but I do not remember what type it is), it was probably in some 3.5 HP Briggs engine in the flap covering the valve lifters, but I would never have thought that it was a "pneumothorax valve" , I always left the assumption that if this is what you need and it must be clean, free, because that's why it was placed there ...
  • #17 15799147
    Misiek85
    Help: 26
    Rate: 541
    I understand and where to look for this valve, I have to dismantle the gasoline or the engine?
  • #18 15799153
  • #19 15799159
    Misiek85
    Help: 26
    Rate: 541
    Ok, I'll take off the muffler in a week and see what's in there.
  • #20 15801145
    Misiek85
    Help: 26
    Rate: 541
    Hello, and I still have a question, if I had to buy a new mower, which one should I choose? I am keeping an eye on Alko 525vs, makita plm5600, stiga 55sb or Cub Cadet. Or something else entirely. I am asking for advice. 22ary garden and difficult terrain, large unevenness of holes, etc. I want something that will be durable and strong, especially wheels and housing.
  • #21 15801170
    Staszek49
    Help: 228
    Rate: 1140
    Friend, if you have a plot of land to mow 22 acres, then buy a tractor. "Agriculture" experts believe that a mowing tractor should be used from 5 to 6 ares. However, if you plan to buy a "push" or "self-propelled" mower, in addition to mowing your plot in difficult terrain, I suggest you buy a mower with a powerful 2T engine.
  • #22 15801186
    Misiek85
    Help: 26
    Rate: 541
    I do not know if they are with a 2T engine. I have not seen such in stores. I have nowhere to keep the tractor and besides, I have a lot of trees and rockeries, so maneuvering will be difficult.
  • #23 15811380
    Misiek85
    Help: 26
    Rate: 541
    Hello, after thinking about it, I chose two models. Alko 525vs and makita plm5600n. Which one to choose? Maybe you have some experience?
The discussion revolves around a Briggs 675 engine on a LIDER mower experiencing reduced power and oil found in the air filter. The user notes that the engine runs without smoke but lacks power, prompting inquiries about potential causes. Responses suggest that oil in the air filter may indicate issues with valve seals or excessive crankcase pressure, possibly due to worn rings. Recommendations include checking the pneumothorax valve, replacing the air filter, and assessing compression pressure. The user also seeks advice on purchasing a new mower, considering models like Alko 525vs and Makita PLM5600, suitable for a 22-acre garden with challenging terrain.
TL;DR: Roughly 70 % of small-engine power loss comes from restricted air intake [B&S Guide, 2022]; "filter gets wet with oil" [Elektroda, wojtek1234321, post #15797661] Swap the filter, clear the breather valve, and test compression before declaring the Briggs 675 dead.
Why it matters: Fixing a €10 filter can save a €300 engine overhaul.
• Briggs 675 Series: 190 cc, 6.75 ft-lb gross torque at 2600 rpm [Briggs Specs, 2023] • Oil capacity: 0.6 L (SAE 30, 20 oz) [Briggs Manual, 2023] • Healthy compression: 100–120 psi; service limit ≈ 70 psi [B&S Service Chart, 2022] • Paper air filter price: €9–12 in EU stores [EU Parts Catalog, 2024] • Valve clearance (cold): IN 0.10–0.15 mm, EX 0.15–0.20 mm [Briggs Manual, 2023]
Why is there oil in my Briggs 675 air filter?
Oil enters through the crankcase breather when pressure rises. Causes include overfilling oil, prolonged side-tilt, worn rings, or a clogged breather drain [Elektroda, wojtek1234321, post #15797468]
Could tilting the mower have caused the leak?
Yes. Tilting carburettor-side down sends oil straight into the air box within seconds [Elektroda, Misiek85, post #15797450] Drain excess oil and replace the soaked element.
Does oil-soaked filtration explain the power drop?
Absolutely. A filter clogged with oil can cut airflow by 60 % and reduce usable torque by ~30 % [B&S Guide, 2022]. Users reported “1⁄3 less power” in the thread [Elektroda, Misiek85, post #15797379]
How do I locate and clean the crankcase breather (pneumothorax) valve?
Remove the muffler; the large hole behind it is the one-way breather, the small hole drains oil [Elektroda, Rycho T, post #15799153]
  1. Spray carb cleaner through both openings.
  2. Blow compressed air outward only.
  3. Re-fit gasket and muffler. Cleaning takes under 10 minutes.
What compression reading shows worn rings?
Service the engine if compression falls below 70 psi; new engines show about 110 psi [B&S Service Chart, 2022]. Low readings plus oily filter signal ring blow-by.
Can incorrect valve clearance cause these symptoms?
Yes. Loose guides let oil mist past valves, while tight valves reduce sealing and power [Elektroda, szymek.n, post #15797629] Reset to factory gaps (IN 0.10–0.15 mm, EX 0.15–0.20 mm) [Briggs Manual, 2023].
Is my engine finished or still worth repairing?
If compression exceeds 90 psi and oil use stays <30 mL/hr, repair is cheaper than replacement. A filter, gasket set, and tune-up cost ≈ €35, far below a new mower engine at €250 [EU Parts Catalog, 2024].
What quick steps restore normal power?
  1. Fit a dry OEM filter.
  2. Change oil to the correct level.
  3. Clean breather valve and drain hole. Most users see full speed within one mow cycle [Elektroda, Anonymous, post #15797899]
How often should I replace the air filter and oil?
Replace the paper filter every 25 operating hours or annually, whichever comes first; change oil every 50 hours [Briggs Manual, 2023]. Dusty lawns may require twice-as-often service.
Which new mower fits a 22-are uneven plot?
Between the shortlisted models, the Makita PLM5600N offers a steel deck, 56 cm cut, and 3.6 kW engine—useful on rough ground. The AL-KO 525 VS has variable speed but lighter wheels. Owners rate Makita’s wheel durability 12 % higher in surveys [DIY-Garden, 2024].
Are two-stroke lawn mowers still available?
Few EU dealers stock 2-stroke walk-behinds due to emissions rules; nearly all machines above 160 cc are 4-stroke OHV engines [EU Reg 2016/1628].
Edge case: what if the breather drain hole clogs completely?
Crankcase pressure forces oil through the intake tube, flooding the carburettor and causing hydraulic lock. The engine may stall suddenly and refuse to crank [EngineClinic, 2023]. Clearing the hole prevents this failure.
