Automatic gate opening after driving under the gate - how to do it
Pawel2990 15579 8
  • #1 16577562
    Pawel2990
    Hello, I was looking for such a system of opening the gate with the help of a remote control that I would mount in the car and when I drive up to the gate it will open by itself. For now, I do not have a system yet, because it may be that I will make the actuator myself.
  • #2 16577633
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    Look for the thread on the electrode.
    As I know life, you probably want it to open earlier and to smoothly enter the property without stopping.
  • #3 16577647
    jurek54
    Help: 7
    Rate: 73
    I recommend the PROXIMA remote control, available on the popular auction site along with assembly instructions. It is installed in the vehicle and attached to the traffic lights or horn. I myself have one installed and I control it with an entrance gate - one light pulse, and a garage door - two impulses. Works great and I don't have to remember about the standard remote control.
    Greetings.
  • #4 16577886
    kotbury
    Gantry automation specialist
    Help: 2100
    Rate: 3631
    You can choose from fully automatic solutions -
    the cheapest bluetooth transponder (approx. PLN 200 - range up to 10 m but as a short range radio - a bit unpredictable), induction loop - reliable, used professionally but expensive (from PLN 800 two-channel and requires demolition of the driveway for the wire position) and a similar price detector radar (there are cheap radar detectors but they work on everything, a radar that detects the direction of movement and size - that is, the ability to distinguish between auto - a person starts from 700 PLN and you need two).
  • #5 16577944
    PROXIMA sj
    Radio controllers specialist
    Help: 103
    Rate: 220
    Maybe colleagues familiar with SOMFY solutions using geolocation (GPS),
    widely advertised in the media, write about the details of this solution and assess its suitability for a colleague Pawel2990?
    PROXYMILIAN
    PROXIMAsj
    Polna 23A, Toruń, 87-100 | Company Website: www.proxima.pl
  • #6 16578047
    lamerb
    Help: 86
    Rate: 166
    Or maybe a GSM controller? Even Proxima?
    When you are close to home, you release the arrow and the gate opens!
  • #7 16578142
    andrzej lukaszewicz
    Help: 626
    Rate: 2121
    And it certainly is easier (safer when driving a car) than pressing the usual button on an ordinary remote control ???
  • #8 16578180
    janek ie
    Help: 8
    Rate: 17
    Hello, there is also the possibility of connecting additional photocells, which after interruption will give a signal to open with temporary shutdown.
    .If only talking about leaving the property, GSM is also a good option or an induction pent, but if a colleague writes, you would have to cut or dismantle the ankle.
  • #9 16578181
    lamerb
    Help: 86
    Rate: 166
    And it depends on what car you have and the degree of its integration with the phone.
    The advantage of this solution is the ability to open the gate regardless of the distance from the property - if you are in a hurry, you open 2 intersections. How is it not easier to just use a regular remote control?
A user seeks a system to automatically open a gate upon approaching with a vehicle, potentially using a self-made actuator. Responses suggest various solutions, including the PROXIMA remote control, which can be installed in the car and is activated by light pulses. Other options include Bluetooth transponders, induction loops, and radar detectors, each with varying costs and reliability. Some users mention the possibility of using GSM controllers or integrating additional photocells for gate operation. The discussion highlights the importance of ease of use and safety while driving.
