Car GPS Locator With Geofence Trigger to Activate Home Devices or Gate at 200m Range
Ozzi O 3120 7
  • #1 16779822
    Ozzi O
    Hi :D I am looking for such a locator which will be placed in the car and when I am e.g. 200m from home it will send a signal automatically to the receiver at home. What I mean is that e.g. the receiver, after receiving the signal, will switch on the kettle in my flat or e.g. open the entrance gate. Could anyone advise me what company or where I can get something like this? Thank you in advance for your help ;) .
  • #2 16779981
    marek216
    Help: 1077
    Rate: 932
    I have not come across such a standalone solution. You can look for such options in SOMFY systems they have geolocation gate control, as for switching on devices I don't know if it gives such an option.
  • #3 16780137
    Ozzi O
    Well, yes, but since it controls the gate that means it can send a signal right? So, for example, the signal will be sent to the microcontroller and then 230V can be switched on via the circuit. Do you think something like that is possible?
  • #4 16780223
    TvWidget
    Help: 472
    Rate: 697
    A Bluetooth Low Energy (Beacon) tag placed in the car can be used for this purpose. It usually sends a message about its existence every 1 sec or so. Most BLE tags have a short range (max. 50m). However, there are some "long range" ones with higher transmitter power. With so-called optical visibility, they can easily achieve a range of several hundred metres.
  • #6 16781266
    Ozzi O
    Do you think this with this signal to the micro controller which in turn will fire through the device circuit? is a good idea?
  • #7 16781662
    marek216
    Help: 1077
    Rate: 932
    Ozzi O wrote:
    Do you think this with this signal to the microcontroller which in turn will fire through the device circuit? is a good idea?
    You want to use too many intermediary devices to perform one action. You can. Just does it make sense?
    colok
    A GPS locator with zone detection can be used. These include, for example, locating devices from teltonika or the Polish albatros S8.3.
    After entering the zone, the device sends an SMS to a programmed number.
    This SMS is sent to the GSM controller, which has a relay output.
    NP. https://e-sklep.zamel.pl/produkt/sterownik-gs...4guOnjAxWv6TW0eX_D-4I9qLeRc8GzIgaArLrEALw_wcB
    but it costs 440PLN
✨ The discussion focuses on finding a car GPS locator with geofence capabilities to trigger home automation actions, such as switching on devices or opening a gate at approximately 200 meters from home. SOMFY systems were suggested for geolocation-based gate control, though their ability to switch household devices is uncertain. Bluetooth Low Energy (BLE) beacons with extended range were proposed as an alternative, but typical BLE range is limited to about 50 meters unless optical visibility conditions are met. Another solution involves using smartphone geolocation apps combined with a Raspberry Pi running Domoticz for home automation. A practical approach includes GPS locators with zone detection, such as devices from Teltonika or the Polish Albatros S8.3, which send SMS alerts upon entering a predefined zone. These SMS messages can activate a GSM controller with relay outputs (e.g., Zamel GRM-10) to control home devices or gates. The discussion also highlights considerations about the complexity and practicality of using multiple intermediary devices for a single automation task.
