TERMAQ ELECTRONIC G-19-02 - what are the most economical settings?
NeroTFP 21162 4
  • Balancing flow and temperature for lowest cost
    #1 16579144
    NeroTFP
    I have TERMAQ ELECTRONIC G-19-02 heater for heating water
    Usually with a fiancee, we bathe in a shower cabin.
    Now the question - what settings of the heater "GAS KNOBS KNOB" and "temperature selection knob"? What are the most economical settings to pay as little as possible for WATER and FOR GAS?
    I read something in the instructions: "If the selector dial is set to the right to the limit, a small water jet is obtained, ie 5.7 dm3
    / min with the highest temperature (at the position of the gas flow knob in the leftmost position), and an even smaller stream is obtained by reducing the flow with the intake valve. If the temperature selection knob is set to the leftmost resistance, a large water jet is obtained, ie 11.5 dm3 / min with the lowest temperature (position of the gas flow knob as above).
    So far, WATER is often very hot, so you can boldly reduce its temperature, but then if more water I WILL USE? What is the most profitable?
    What settings should I choose?
    Lower gas use by turning flame down
    #2 16579231
    Matheu
    Help: 61
    Rate: 305
    And how would you "reduce the gas expense"? - turn the left knob clockwise a little.
    You just twist from the "Big Flame" to "Little Flame" :D
    - the logic / water quantity will remain the same and the water temperature will decrease (and gas consumption too)
    (it's probably not that hard to predict?)
    PS And this pretty fiancée?
    If I helped - click helped
    :wink:
  • #3 16583936
    NeroTFP
    So :)
    Added after 30 [minutes]:
    I also have the fact that Termaq only turns on for me, for example in a shower, I will unscrew more water.
    If you turn on the water so lightly, it does not turn on :) Is it normal that it only switches on with a larger stream of water? :)
    I wanted to "minimize" so that I could save, because as you let WATER go, you lose water :)
    Or maybe it's so ejst?
    Added after 1 [hour] 58 [minutes]:
    If I turn the "TEMPERATURE CHOOSE" knob in the RIGHT then will I have a smaller stream of water?
    Matheu
    Help: 61
    Rate: 305
    My friend,
    I do not know this term, but (on logic):
    under the knobs there are stamps: LEFT KNOB - flame -> gas volume regulation (and also the water temperature regime)
    RIGHT KNOB - "kranik" -> ADJUSTMENT OF WATER QUANTITY (you also regulate the water temperature, but indirectly, the main temp control is the left handwheel)
    It looks like there is a turbine there:
    you unscrew the valve -> water flies more strongly -> runs the turbine -> which generates electricity / spark -> gas ignites -> and heats the water
    And now I am going to sleep. Have fun using the shower. You should already be able to do it ;)
    Good night
  • #5 16584907
    NeroTFP
    Now everything is simpler ... :)
    Thank you :)
