Unusual Windows 10 System Startup Errors: In-depth Analysis and Potential Fixes
5130 6
  • #1 16580656
  • #2 16580721
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    What are these bothers for you? If the system works then you don't have to do anything about it.
    > CldFlt
    You can stop this service and change its startup mode to off.
    > The driver \ Driver \ WudfRd failed to load for the device ROOT \ WPD \ 0000
    Set the start of the User-mode Driver Framework service to automatic:
    https://www.sevenforums.com/drivers/268212-dr...d-failed-load-device-error-2.html#post2886628
    > The DHCP server 192.168.8.1 refused to lease the IP address 192.168.8.100
    Set up the router correctly and assign yourself a different address from the range, set up automatic address retrieval under Windows.
    > I searched the internet but I didn't find anything and what I found didn't help.
    Maybe it's time to learn how to use the search engine?
  • #3 16580730
  • #4 16580737
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    Just enter, for example, CldFlt and read the first 10 links found, generally there should be an answer.
    The same goes for the rest. But as I wrote, if everything works better then it can stay that way.
  • #5 16580750
  • #6 16580759
    Kolobos
    IT specialist
    Help: 17174
    Rate: 10460
    CldFlt, the service is called Windows Cloud Files Filter Driver
    The second service is: Windows Driver Foundation - User-mode Driver Framework
    > I don't have a router. I have an LTE modem.
    Then leave it as it is.
  • #7 16580781
The discussion revolves around unusual startup errors in Windows 10, specifically related to system logs indicating issues with services like CldFlt (Windows Cloud Files Filter Driver) and WudfRd (User-mode Driver Framework). Users report persistent errors during boot, with suggestions to adjust service settings and DHCP configurations. One user mentions using an LTE modem instead of a router, complicating IP address assignments. Solutions include setting the User-mode Driver Framework service to automatic and ensuring correct DHCP settings. After making adjustments, one user noted that the log errors ceased.
