DDR Smalcalda Drill: Sparking Brushes on Commutator - Causes, New 6x6mm Brushes, & Solutions
Pioro33 9414 7
  • #1 16581144
    Pioro33
    Level 19  
    Rate: 77
    I have a drill made by DDR Smalcalda and when I got it, it turned out that there are brushes to replace. Not because of wear, but simply one that burst and the cable fell off. I bought brushes 6x6 [mm] and after assembly they caught the attention of sparking on the brushes. I am not able to say for sure if such sparking is a cause for concern.
    I noticed some facts that may affect this behavior:
    1. The new brushes are profiled at the ends to a round commutator (which I think is a big plus) but the part that connects to the commutator is not smooth, but it still has small fringes, can it reach? Because of this, it does not adhere exactly to the commutator. If this can cause such a problem, I can always try to grind them on but I do not know if I can keep the shape adapted to the round commutator.
    2. The new brushes are as if "less" carbon, that is, the old ones were black, as if all made of carbon, and the new ones probably have some larger admixture of copper dust you can see it by color.
    3. The capacitor on the power supply is quite bad and quite strange at all. The inscriptions on it, unfortunately, not very legible I assume that it is 0.1uF. In addition, the capacitor has a tap on a metal part of the stator. I put a drawing of the capacitor and ask for information why there is an additional tap on the metal part of the stator? Is this a rather rare solution? Can the capacitor itself, which is parallel to the power supply, affect sparking, or maybe this tap on the stator dirty? Thank you for your help.
    Pictures of the drill and sparks during operation:
    DDR Smalcalda Drill: Sparking Brushes on Commutator - Causes, New 6x6mm Brushes, & Solutions DDR Smalcalda Drill: Sparking Brushes on Commutator - Causes, New 6x6mm Brushes, & Solutions DDR Smalcalda Drill: Sparking Brushes on Commutator - Causes, New 6x6mm Brushes, & Solutions DDR Smalcalda Drill: Sparking Brushes on Commutator - Causes, New 6x6mm Brushes, & Solutions
    The capacitor seems to me that it has this structure:
  • #2 16581155
    krzysiozak
    Level 40  
    Help: 512
    Rate: 1156
    Pioro33 wrote:
    But the part that connects to the commutator is not smooth, but it still has small fringes.
    These fringes are not reaching, but this is how you see the commutator contacts that switch the windings in the rotor during motor operation.
  • #3 16582010
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 848
    Hello - have you used replacements or the first better 6x6mm?
  • #4 16582744
    Pioro33
    Level 19  
    Rate: 77
    We didn't understand each other about the stripes :)
    The commutator plates are of course one thing and everything is fine here.
    Just the part of the brush in contact with the commutator is not smooth, I found a picture showing what I mean.
    Brushes were bought in a power tool store, for the drill that I need. Generally, they are not dedicated to my drill because it is historical. Perhaps it is better to choose the material from which they are made. Any hints what to buy and where?
  • #6 16633222
    jar190
    Sparking of brushes, especially new ones, indicates that brushes reach the commutator.
  • #7 16633262
    robokop
    Help: 1763
    Rate: 6376
    First of all, this is a pathology and indicates the wear of the commutator. The plots should be cleaned and in the absence of access to the lathe, use fairly thick sandpaper. I run the device through the autotransformer and apply a piece of paper from the side. It should not be sparking or barely noticeable.
  • #8 18020687
    elektronikq
    Help: 70
    Rate: 614
    And how do you do it on a lathe? Please enter a way.
The discussion revolves around issues with sparking brushes on a DDR Smalcalda drill's commutator after replacing the original brushes with new 6x6mm ones. Users noted that the new brushes have a rough contact surface, which may prevent proper adherence to the commutator, potentially causing sparking. Suggestions include ensuring the brush contact surface is smooth and considering alternative brushes that are better suited for the drill. Concerns were raised about the commutator's wear, with recommendations for cleaning or machining it if necessary. The presence of copper dust in the new brushes was also mentioned as a possible factor affecting performance.
