Changing Drill Heads on Older, Reliable Drills: Step-by-Step Removal Guide
Evenn 119355 17
How do I remove the chuck from an old but reliable drill so I can fit another attachment?
The chuck is mounted on a Morse taper, so it should be removed by separating the taper fit rather than by unscrewing the jaws [#7032979] A simple method is to put an M6 screw with a nut into the chuck so the screw bears on the end of the drill shaft, clamp the chuck, and tighten the screw until the chuck loosens off the cone; if needed, grind the screw tip to fit or use a bearing ball as a spacer [#17510103] Another option is to drive a wedge/puller between the chuck and housing, or tap it off carefully with a hammer and a wooden/chisel spacer [#7031252][#7036463][#7032979] Be careful when hammering, because the shaft can slip out of the Seeger lock in the drill head [#7032979]
  • #2 7031252
    macieja
    Help: 78
    Rate: 266
    The head in these drills is on a wedge. You can do it with a bearing puller.
  • #3 7031260
    leszeksz2
    Rate: 40
    Unscrew the jaws of the chuck (just like you would like a large drill bit) and you should see a screw at the bottom. It should be unscrewed and the handle should come out.
    This screw has a LEFT thread.
    Greetings.
  • #4 7031261
    Evenn
    Rate: 8
    Oh, thank you, maybe today I will look for something like that in the stores
    Unfortunately, my friend, I checked, there is nothing there, maybe the screw has completely worn out over the years because there is nothing there
    Added after 4 [minutes]:
    exactly I would like to put something like this on the drill http://www.allegro.pl/item738782923_nasadka_d...ertarki_wyrzynarka_brzeszczotowa.html#gallery
  • #5 7031334
    niutat
    Level 36  
    Help: 288
    Rate: 757
    Hello, this mount is mounted on a Morse taper and has no screws or wedges. Make a wedge with a cutout for the shaft so that it can be inserted between the handle and the ring on the shaft and try to nail it. You can slightly heat the handle, there is no other way.
    Are you sure this cap will work for you?
  • #6 7031372
  • #7 7031863
    leszeksz2
    Rate: 40
    Confused with the modern handle mount.
    At one time, my father had a slightly different and smaller drill (I don't remember the name), also "age-old" and there was a screw mounting.
  • #8 7032979
    serwis
    Level 37  
    Help: 334
    Rate: 268
    Evenn wrote:
    Hello everyone, I have a small problem, I would like to change the drill heads, as you can see, the drill is quite old but reliable. Sorry if the post is out of place.
    https://obrazki.elektroda.pl/42_1253272166.jpg
    https://obrazki.elektroda.pl/95_1253272400.jpg
    Do not listen to users who have seen a drill for the first time and add to it a theory that does not make sense.
    The fur (drill chuck) in this machine is attached to a Morse No. 2 taper.
    You can download as it writes a day , or put a piece of the mandrel against the base of the handle and hit it vigorously with the hammer.
    In this case, however, there is a risk that the shaft on which the chuck is attached will slip out of the Seger lock in the drill head.
  • #9 7033026
    kortyleski
    Help: 957
    Rate: 3858
    which does not change the fact that no jigsaw attachment can be easily connected with this drill - and even if you buy an attachment that connects the PRCr 13 drill with the PRCR 10 II accessories, it will be so clunky and bulky that you won't do anything with this equipment. Take my word for it, I did the same thing ten years ago when the PRCr 10 II drill was a rarity. It is easier to buy a jigsaw at a market for PLN 50, you can do more with it.
  • #10 7033053
    serwis
    Level 37  
    Help: 334
    Rate: 268
    kortyleski wrote:
    (...) Buy a jigsaw in a supermarket for PLN 50, you can do more with it.
    And if you find a promotion, it will cost PLN 39.99 :D
  • #11 7036463
    kleki
    Help: 95
    Rate: 142
    the website is telling the truth. Głowiczka is loaded on a cone. I have one too (after my late Dad) and the handle is for a cone. The razor is probably older than me. As I remember correctly, you need to hammer a wedge between the housing and the handle. Dad stuck the chisel and it came down. :-)
  • #12 7098603
    Semix
    Hello :)
    Let me join the topic ... today I found such a drill while tidying up the garage. I remember that my late Father once used it in a column holder. When turned on, the drill breaks and sparkles under the brushes. Sometimes it does not turn on at all and you have to turn it to catch it. As far as I know, such a symptom is worn out brushes. And hence the question - where to get such?
    greetings :)
  • #13 7098956
  • #14 7099015
    jendrula60
    If the drill does not reach full power (revolutions) and the brushes are - even very short - break the rotor and you will not do anything. If you have brushes, you can buy slightly larger ones and fit them to the brush holder with sandpaper. The spring must fit inside.
  • #15 7100086
    leszeksz2
    Rate: 40
    But too short brushes may not reach the impeller, and no contact may be possible.
    Strong sparking is usually something wrong with the brushes, e.g. short. They can also hang in the brush holder. Check that they are walking loosely.
    Sparking can be affected by dirty commutator grooves.
    In your case, I bet on suspended or short brushes.
    You can also make extra brushes yourself.
  • #16 7105355
    Topolski Mirosław
    Moderator of Electrical engineering
    Help: 355
    Rate: 1619
    Do not make a theory about brushes anymore, because here is clearly the rotor to be replaced
    .......... you have to twist it to get it ....
  • #17 9741744
    Evenn
    Rate: 8
    thanks a lot, I close the topic
  • #18 17510103
    gosp
    Printers specialist
    Help: 39
    Rate: 45
    I will join, because no one wrote it, and maybe posterity will benefit - in a very simple way, without a hammer and puller, you can remove any drill chuck from a Morse taper - you only need an appropriate screw with a nut, e.g. M6, depending on the size of the handle - put inside handle a screw with a nut about 1.5 cm from the end of the screw, tighten the handle with a key, and after inserting a key appropriate for its head on the screw, start screwing it - then the screw will loosen the drill chuck from the cone - of course, you need to check the diameter of the hole inside the handle - the screw must fit into it (have a smaller diameter) so that it can rest its end against the end of the drill shaft - you can alternatively grind its end to the appropriate diameter, or use a ball from a bearing with a suitable hole diameter as a spacer.
✨ The discussion revolves around changing drill heads on older drills, specifically those with a Morse taper mount. Users suggest various methods for removal, including using a bearing puller, unscrewing the jaws of the chuck to access a left-threaded screw, and employing a wedge to separate the chuck from the shaft. Some participants mention the challenges of finding compatible attachments for older models, particularly for a Celma drill. Additionally, there are inquiries about troubleshooting issues related to worn brushes and rotor problems in older drills, with suggestions for sourcing replacement parts and DIY solutions for brush fitting.
