Skoda Octavia 3 - VCDS Cornering Light Adaptations, Leuchte12NL LB45 & Leuchte13NL RB5 Channels
henryk777 9300 3
  • #1 16625803
    henryk777
    Rate: 36
    Hello, I have a question, did any of the forum users play with VCDS adaptations of cornering lights in the Skoda Octavi Mk3? Theoretically, from what I came from the English pages it follows that the procedure is as follows: We enter 09-Central Electricity, 16-Authorized Access-enter login 31347 then go to 10-Adaptations and in the channel: (5) Leuchte12NL LB45-Lichtfunktion B12 select the left halogen as also in the channel :( 5) Leuchte13NL RB5-Lichtfunktion B13 mark the right halogen. It's just a theory in practice I will find out on Thursday I will have on Octavie Mk3 website
  • #2 16626574
    daro31ie
    Automation specialist
    Help: 366
    Rate: 650
    I coded VCDS, lighting went without a problem.
  • #3 16630004
    henryk777
    Rate: 36
    In Skoda Octavi 3?
  • #4 21886959
    Jar28
    The previous OC3FL went without a problem, it was a 2017 import. Now I have a 2020 from PL showroom and I have the information no module. Someone suggest if I need to buy a module? What to do? Thanks in advance.
