Setting up the FreeSat v8 meter and antenna for Cyfrowy Polsat
quiet123 8415 10
How should I set up a FreeSat V8 meter and LNB for HotBird 13E to get Cyfrowy Polsat HD channels working when signal quality is poor or missing?
The problem is probably not the antenna or LNB setting: a working neighbor receiver getting 80% strength/quality means the dish is aligned and the error message “This channel is not included in your subscription” points to missing card permissions, not reception [#16690240] The ESI-88 receiver can also use outdated basic transponder parameters, so it may show no signal even though it still searches channels [#16690240] One suggested step was to restore factory settings, unless the ESI-88 ignores it [#16690266] If you still suspect a reception fault, connect the meter directly after the tuner/receiver and check the cable path, because roof settings can distort the installation [#16692253]
  • #1 16689144
    quiet123
    Rate: 8
    Hello, I have a question - I bought a SAT meter occasionally. I want to set up the antenna for digital polsat and I do not know how to set all options so that the reception is ok - I can't tune HD channels at the moment. I'm setting up the HotBird 13E satellite and I don't know what exactly to choose in the LNB frequency? Currently, I have chosen Universal [9750-10600]. And I can't get into good quality.
    I will add that I have two transponders selected by default -
    12188 V 27500
    11158 V 27500
    DAM-SAT
    Sadowa 10, Żnin, 88-400
  • #2 16689163
    _kli_
    Help: 759
    Rate: 1035
    What model exactly?
    Does it have DVB-S2 measurement?
  • #3 16690196
    quiet123
    Rate: 8
    Freesat V8 meter - not very popular, but I can do it. MER, unfortunately, does not show. I selected transponders that support stations in HD [checked in the net] and set the plate, unfortunately still a problem at the bottom - on the meter the programs receive on the roof and in the apartment, and on the first installation of the decoder the signal strength - 0. The best is that I took another decoder from neighbor - and here 80% strength and quality, but after searching the channels it displays info
    DAM-SAT
  • #4 16690240
    andpol 33
    Help: 513
    Rate: 1145
    "This channel ..." means there is no permission on the card. Since another decoder is working, the antenna is working. Don't you have ESI-88? It will not show the signal because it has outdated basic tp parameters. And the curiosity, despite the lack of signal on the indicator, will search for channels.
  • #5 16690266
    _kli_
    Help: 759
    Rate: 1035
    quiet123 wrote:
    on the meter they receive programs on the roof and in the apartment
    Which?
    quiet123 wrote:
    on the first installation of the decoder signal strength - 0
    Restore factory settings (unless the ESI-88 does nothing).
    On all channels? The card has current permissions?
  • #6 16691339
    quiet123
    Rate: 8
    The decoder is ESI-88. On it, I can't search for other channels except for encoded polsat, because it has a preset frequency and is after factory settings - the screen displays only the first installation, I can't even enter MENU. What to do in this case? Search despite the fact that it does not display the signal ??
    DAM-SAT
  • #8 16692253
    bolpan
    Rate: 8
    Roof settings can distort the installation. After setting the "top" connect the meter directly after the tuner and see what it shows you because maybe the fault lies on the cable side
    Moderated By arko100:
    3.1.11. Do not send messages that are misleading.
  • #9 16692278
  • #10 16692285
    _kli_
    Help: 759
    Rate: 1035
  • #11 16692420
    quiet123
    Rate: 8
    mihal2002 wrote:
    quiet123 wrote:
    I can't search for other channels on it
    What others The decoder is designed for pay TV services.
    I noticed due to the fact that the frequency is fixed at the installation. At the neighbor decoder [Mini HD] it searches for all channels - also uncoded.
    In that case, I think the topic is closed, a matter of decoder, I will try. Thanks for all the answers. Greetings.
    DAM-SAT
✨ The discussion revolves around setting up a FreeSat V8 meter and antenna for receiving Cyfrowy Polsat channels via the HotBird 13E satellite. The user is experiencing difficulties tuning HD channels and achieving good signal quality. Initial settings include a Universal LNB frequency of 9750-10600 and two transponders: 12188 V 27500 and 11158 V 27500. Responses suggest checking the model's capabilities, particularly if it supports DVB-S2 measurement, and verifying the decoder's settings, as the ESI-88 model may have limitations. It is recommended to connect the meter directly to the tuner to isolate potential cable issues. Ultimately, the user concludes that the problem may lie with the decoder itself, as a neighbor's Mini HD decoder successfully searches for all channels.
