Junkers ZSB-16-1 A23: Resolving Error F0, P4 Startup Issue, Mainboard Replacement Debate
Gwizdek_N 10512 5
  • #1 16582814
    Gwizdek_N
    As the topic. Initially, the furnace was reset (reset button for 5 seconds) and returned to normal operation. Now, unfortunately, it comes to P4 during startup and goes into error F0.
    The service technician, without touching the furnace, stated that the mainboard needs to be replaced although in the manual they write about loose connections, etc.
    What do you think about this case ??
  • #2 16586844
    meaverick
    Help: 109
    Rate: 242
    Something on the ignition module. Here's the description. MANUAL
    • Junkers ZSB-16-1 A23.pdf (2.79 MB) You must be logged in to download this attachment.
  • #3 16587484
    serwisszulborski.pl
    Heating systems specialist
    Help: 360
    Rate: 1448
    Internal disc error. To be replaced. Check only the power connection and voltage.
  • #4 16631253
    Gwizdek_N
    The fault does not occur. I have disconnected all possible electrical connections, cubes, etc. cleaning contacts, compressing springs, etc. The furnace has been working flawlessly since July 15 :-) (let them not scare you :-)
    Thank you for replying to the thread. greetings
  • #5 16631855
    serwisszulborski.pl
    Help: 360
    Rate: 1448
    You are lucky, yesterday I had the same case ... reset, improve the electrical contact on the wires and it works. However, I see the causes in the radio transmitter of the room regulator. If the fault returns, I will first replace the "Chinese" controller.
  • #6 16632539
    dariofestyn
    And I recommend it. They can do problems!
