Refrigeration unit Thermo King V-300 max 20 - how much refrigerant
jacekwwy 11844 2
  • #1 16584528
    jacekwwy
    Level 19  
    Help: 39
    Rate: 108
    Hello, I have a Thermo King V-300 refrigeration unit max 20 R 404A refrigerant. The unit is powered by a compressor as well as a 380v network. My problem is that the aggregate is not cooling well, which turned out to be too low a factor (checked with an instrument) and the stairs begin that nothing writes anywhere, how much of this factor should be in the system ??? I would be grateful for any help how much this factor can be or how to check it :)
    SP7SEC
    Help: 110
    Rate: 410
    In the documentation, they say about 3.85 lbs, which is about 1500 to 1600 g, I would not exceed 1300 g because these condensers do not make a bit at 404a
  • #3 16597563
    jacekwwy
    Level 19  
    Help: 39
    Rate: 108
    And that's about it :) thanks for helping the topic to close
