What does DS mean on the cable modem and why does it glow in orange?
WujekAdolff 28293 3
  • #1 16584558
    WujekAdolff
    Hello in recent times I noticed a clear drop in internet speed from 60-70Mb to 5-30Mb I do not know what is the modem is Arris tm822 noticed that it is slower when the LED diode on the modem shines as the only orange, and not like the other green. If, however, it shines green with the rest, the internet is as it should be. How do you think to call someone from multimedia or bury something yourself? In total, the cable that provides the internet is unstable but it does not explain the speed because even if it is fully inserted it can also net. What is going on? ^^
  • #2 16584779
    mbo
    Help: 2333
    Rate: 845
    DS means Downstream.
    The orange LED means that the modem does not work on all carriers in this direction - the problem is to the operator.
  • #3 16585077
    KOCUREK1970
    Help: 3860
    Rate: 5488
    What does unstable cable mean?
    This can be the potential cause of problems.
  • #4 16586213
    jimasek
    Help: 3783
    Rate: 2681
    This is probably the most sensible answer in this topic.
