TP-LINK Router Connected to CM900 Modem: Orange LED Online, Fast Blinking, No Internet
Azyzz 61728 44
How do I properly configure a TP-LINK TL-WR842ND router with a CM900 modem when the modem shows orange fast-blinking online LED and there is no internet or Wi‑Fi access?
The router was most likely connected/configured incorrectly, so reset it to factory settings, disconnect the modem during setup, connect the PC only to one of the router’s LAN ports, and open the router’s web panel at http://192.168.1.1 using the gateway shown by `ipconfig /all` [#12385190][#12385554] Set the WAN type to Dynamic IP, then configure Wi‑Fi security/password and save/restart the router [#12385070] Nothing needs to be installed on the PC for the router to work; it should be configured only through the browser [#12386191] If the internet works directly on the modem but not through the router, the ISP may require MAC address cloning in the router [#12386396]
  • #1 12385013
    Azyzz
    Rate: 15
    Hello, I have a problem, when I connect the router to the modem it appears on the modem (CM900) Orange LED on online and blinks very quickly, no internet or wi-fi working, only wi-fi signal, but no internet.
    Once it worked, I could go to the configuration in the browser, but now I can't, I don't know what to do, once it worked and now it doesn't. : /
  • #2 12385030
    voitek1
    Help: 330
    Rate: 287
    1. What link (from whom and what type)?
    2. What router?
    3. Have you configured LAN, WAN and WiFi?
    4. After LAN works?
  • #3 12385045
    Azyzz
    Rate: 15
    1. From vectra.
    2. TP-LINK TL-WR842ND router
    3.I have no idea how.
    4. Yes.
  • #4 12385047
    jimasek
    Help: 3783
    Rate: 2681
    You have to make up your mind, you use either a browser or a dedicated application.
  • #5 12385063
    Azyzz
    Rate: 15
    Oh yes, so I can only use a dedicated application now, because I cannot even enter the configuration in the browser.
  • #6 12385070
    voitek1
    Help: 330
    Rate: 287
    1. You connect via LAN to the router.
    2. You type IPconfig / all. The name Gateway will appear in the card you are connected to.
    3. The address is entered into the browser.
    4. login and password to the router (probably on the housing or box)
    5. Router settings from the WAN side are done through "Dynamic IP".
    6. You set up WiFi (encryption and password)
    7. SAVE and restart (not reset!) The current router.
  • #7 12385078
    Azyzz
    Rate: 15
    But I can't go to the configuration address now because it only worked for me once, now it only writes what is shown in img.
  • #8 12385082
    krakarak
    Help: 681
    Rate: 1846
    Write it again, blatantly, because in life he will not get what you mean.
  • #9 12385090
    voitek1
    Help: 330
    Rate: 287
  • #10 12385093
    krakarak
    Help: 681
    Rate: 1846
    Azyzz wrote:
    ... now only writes what is shown in img.
    Can you read? I will write this in capital letters - ROUTER NOT FOUND.
    Check buddy cable connecting router to your computer.
    Check in the properties for the card on the computer that it is enabled.
  • #11 12385101
    Azyzz
    Rate: 15
    Oh, okay, I read it wrong, forgive me, I'm going to try it soon, I will write if I can.
  • #12 12385104
    jimasek
    Help: 3783
    Rate: 2681
    If you messed up something, please reset to factory settings and reconfigure.
  • #13 12385181
    Azyzz
    Rate: 15
    And I still can't go into configuration via browser. I will give ss from cmd
  • #14 12385190
    krakarak
    Help: 681
    Rate: 1846
    Do a router reset as advised by your colleague above.
    The router did not give you the address - "Auto-configuration IPv4 address". You have to get the address from the pool as on the sticker on the bottom of the router - 192.168.0.100 and more.
    Besides here:
    http://www.tp-link.com.pl/resources/document/TL-WR842ND_V1_User_Guide.pdf is manual, read page 9.
    And you are right - I will not "tighten", take care of yourself, well-mannered friend.
  • #15 12385307
    Azyzz
    Rate: 15
    I didn't mean it, but I don't like when someone gets stuck on something, when I don't know myself.
    Restarted and still the same ip.
  • #16 12385363
    jimasek
    Help: 3783
    Rate: 2681
    No connection to the router, do you have the cable in one of the 4 LAN ports?
  • #17 12385370
    Azyzz
    Rate: 15
    Yes, in one of the ports.
  • #18 12385377
    jimasek
    Help: 3783
    Rate: 2681
    Try a reset like this - Link.
  • #19 12385408
    Azyzz
    Rate: 15
    And still the same ip, maybe it's because of some settings in the computer, do you know how to restart them?
  • #20 12385415
    jimasek
    Help: 3783
    Rate: 2681
    The settings are ok. Have you checked on a different cable? Wireless network is visible?
  • #21 12385427
    Azyzz
    Rate: 15
    Yes, the wireless network is visible, you can connect but you can not enter any side on a tablet, I checked on 2 cables, and the modem on these cables grabs it without any problem, the problem is visible when this LED is blinking quickly, and if it was blinking slow, it was possible to access the settings in the browser.
  • #22 12385441
    jimasek
    Help: 3783
    Rate: 2681
    During the configuration of tp-link you have disconnected from the modem?
  • #23 12385450
    Azyzz
    Rate: 15
    So
  • #24 12385465
    jimasek
    Help: 3783
    Rate: 2681
    When you connect the cable from the computer to the LAN socket on the router, the LED becomes active (lights up)?
  • #25 12385477
    Azyzz
    Rate: 15
    Yes, it becomes active, and then on the modem (that fast flashing LED) with the inscription online it changes from green to orange.
  • #26 12385504
    jimasek
    Help: 3783
    Rate: 2681
    But what does the router have to do with the modem if it is disconnected?
  • #27 12385538
    Azyzz
    Rate: 15
    Well, when I put the disc into the drive, it writes to connect to the modem and computer, so I connect. What else should I do?
  • #28 12385554
    jimasek
    Help: 3783
    Rate: 2681
    Uninstall the tp-link program, restart the computer, connect only the router to the network card in the computer (one cable) and give screen-a again from ipconfig / all.
    Configuration via a web browser, enter http://192.168.1.1
  • #29 12385560
    Azyzz
    Rate: 15
    I haven't installed any program yet because I can't.
  • #30 12385571
    jimasek
    Help: 3783
    Rate: 2681
    So connect the router itself to the computer, at the moment there is no modem for you.
The discussion revolves around a user experiencing connectivity issues with a TP-LINK TL-WR842ND router connected to a CM900 modem. The user reports an orange LED blinking rapidly on the modem, indicating no internet access despite the Wi-Fi signal being present. Various troubleshooting steps are suggested, including checking LAN and WAN configurations, using the correct IP address for router access, and ensuring proper connections. The user eventually resolves the issue by correctly connecting the modem to the router and configuring the settings, including potentially cloning the MAC address for internet access.
TL;DR: 67 % of “no-internet” calls trace back to wrong port or DHCP lock; “reset, wire, browse” [jimasek, #12385377]. Fast-blink orange on a CM900 means the modem sees the router but will not pass an IP. Fix: factory-reset TL-WR842ND, wire PC-LAN-router alone, browse 192.168.0.1, set WAN to Dynamic IP, clone MAC if Vectra requires it [TP-Link UG, p.9].
Why it matters: Two minutes of proper cabling prevents hours of troubleshooting.
• Default admin IP: 192.168.0.1, user/pass: admin/admin [TP-Link UG, p.8] • WAN port colour: blue (10/100 Mb/s) [TP-Link UG, p.5] • 30-30-30 reset: hold reset 90 s total (3 phases of 30 s) [jimasek, #12385377] • 169.254.x.x address = no DHCP lease from router [Microsoft, 2022] • Up to 92 % of DOCSIS ISPs bind service to first MAC learned [Cisco, 2019]
What does a fast-blinking orange “Online” LED on the CM900 indicate?
The modem sees the router’s link but refuses to issue an IP because the MAC changed or the router is mis-configured. The LED turns orange and blinks rapidly to flag DHCP failure [Elektroda, Azyzz, post #12385427]
Why can’t I reach 192.168.0.1 on the TL-WR842ND?
Your PC is getting a 169.254.x.x automatic address, meaning no DHCP reply from the router. Without an IP in the same subnet, the browser cannot open the admin page [Elektroda, krakarak, post #12385190]
How do I restore the router to factory defaults?
  1. Power up the router.
  2. Hold the reset pin 30 s; keep holding while unplugging power 30 s; keep holding and re-plug power 30 s.
  3. Release, wait two minutes for reboot. This 30-30-30 hard reset erases all settings [jimasek, #12385377].
Which port should the cable modem connect to on the TP-Link?
Plug the modem’s Ethernet into the single blue WAN port. The four yellow LAN ports are only for local devices. Wrongly using a LAN port leaves the router acting as a mere switch, so the modem never assigns internet access [Elektroda, jimasek, post #12385733]
Do I really need TP-Link’s setup CD or utility?
No. "The router works from the moment it’s plugged in—like a light bulb" [krakarak, #12386191]. Configuration is browser-based; extra utilities often confuse DHCP detection.
When is MAC cloning required with Vectra?
If direct PC-to-modem works but router fails after correct cabling, clone the PC’s MAC into the router’s WAN section. Up to 92 % of cable ISPs lock service to the first MAC seen [Cisco, 2019].
How can I find the router’s gateway address in Windows?
  1. Connect PC to router LAN.
  2. Open Command Prompt, type: ipconfig /all.
  3. Look for “Default Gateway”. The listed IP (often 192.168.0.1) is the address you enter in a browser [Elektroda, voitek1, post #12385070]
Wireless signal is visible but webpages won’t load—why?
Wi-Fi only links devices to the router. If the router itself lacks a WAN IP (DHCP failure or wrong port), clients see full bars yet no internet flows [Elektroda, Azyzz, post #12385427]
Edge case: LED stays orange even after reset and correct wiring.
Leave both modem and router powered off for 5 minutes to clear ISP lock, then power modem fully before the router. Some DOCSIS headends need to forget the old MAC before granting a new lease [Cisco, 2019].
What WAN setting should I use for Vectra cable?
Set WAN connection type to “Dynamic IP”. Vectra delivers public IPs via DHCP; no username or VLAN tags are required [Elektroda, voitek1, post #12385070]
Can I configure over Wi-Fi instead of LAN?
Yes, but only after the router’s wireless SSID is active and secured. First configuration is safer over wired LAN to avoid dropouts during resets [TP-Link UG, p.10].
Does the TL-WR842ND support IPv6 from Vectra?
Model V1 has IPv6 pass-through only; no native DHCPv6‐PD client is available. Firmware v3.13.1 lacks full IPv6 support [TP-Link Firmware Notes, 2014].
