Orange diode in the computer at the entrance of the cable from the Internet
kola27 27918 5
  • #1 18653177
    kola27
    I replaced the graphics card and noticed that the orange LED at the entrance to the Internet cable was on. Anyone know what is causing it.
  • #2 18653233
    clubber84
    Help: 451
    Rate: 1749
    The orange diode at the Internet cable connector lights up due to the correct connection to the modem/router, and thus that you are connected to the Internet.
  • #3 18653235
    kola27
    So it's not a bad thing?
  • #4 18653239
    clubber84
    Help: 451
    Rate: 1749
    And is there internet?
  • #5 18653276
    Zwierzak_PAH
    Help: 127
    Rate: 263
    Most often there are 2 diodes.
    First:
    Yellow - lit means connected, flashing is data transmission, off no connection,
    Second (may have 2-3 colors):
    Green, yellow, orange - the colors indicate the speed of the lan. But the colors are contractual manufacturers, so you need to check the manual of the disc to know. In the case of 2 colors, the lack of light also means some speed.
    One LED is described as 'link', the other as 'speed'.
  • #6 18653280
    kola27
    There is internet, everything works, just a little worried about it.
    Okay, I know everything now and I'm closing the post. Thank you very much for your help.
