Huawei P8 - Unable to Make Calls Despite Full Signal, Working Internet & Text Messages
kongomaj 7839 2
  • #1 16585037
    kongomaj
    Help: 5
    Rate: 20
    I have a Huawei P8 phone. The range works, the cards from every network work, the range is full, the Internet after cell data works, text messages come. The problem is I can't call anywhere. When he wants to make a call, there is simply silence. I did a hard reset, searched all settings, tried many solutions, changed to 2g, then 3g and it still can't be called. I saw that there was such a problem in many people but somehow I do not see a specific and good solution. I am asking for advice if someone had a similar problem and dealt with it.
  • #2 16585108
    viayner
    Help: 1563
    Rate: 2052
    Kaki android? maybe in the access configuration you forbade the application to make connections or use the network? At least this is the case with "9" as if it should be like you have the latest android.
    Best regards.
  • #3 16585139
    nutergsm
    Help: 1034
    Rate: 1665
    Try to upload the firmware again.
