Beeping Electrical Appliances: Computer Power Supply & Network Transmitters - Load & Brands
taken 16254 21
Why do my computer power supply and powerline network adapters sometimes emit a short squeaking sound even when the load does not change?
The noise is most likely coil whine or other acoustic interference from a switched-mode power supply, not a sudden load change [#15144571][#15144659] If the same symptom appears in different devices and even on a new PSU, you should suspect the mains installation or external interference and test the device in a completely different place, e.g. at a friend’s home [#15145810][#15149278] A network analyzer or voltage check is also recommended, because one reported case turned out to be poor contact in the supply line and the problem disappeared after the terminals were replaced [#15155431] If the sound comes from a specific coil or choke, gluing/potting the part can sometimes help, though it is not guaranteed [#15144699][#15144659] In some cases there is no real fix beyond tolerating it or getting used to it [#15144659]
  • #1 15144414
    taken
    I know this topic has been discussed many times but maybe someone has come across something like this.
    From time to time I do not say that the power supply in the computer is squeaking quietly all the time, I connected it to the meter and during the squeaking the load is the same all the time, so it's not the fault of the sudden load ... The old power supply squealed, now the new one and all the time the same effect - models and different power supply companies.
    In addition, I have network transmitters at home (LAN network over the power grid) and, interestingly, they also squeal from time to time, but when they start, it's not for a moment, like the power supply for 3-4 seconds, it can only squeal for 2-3 days and suddenly it stops and everything goes back to normal standards....
    The power supply beeps from time to time and the beeping lasts about 3-4 seconds....
    Has anyone experienced such an effect?
    Regards
    Yes
  • #2 15144571
    slawekjang
    Rate: 21
    It's possible that coil whining is the cause. There are ways to seal them, but I've never done anything like that.
  • #3 15144601
    cirrostrato
    Help: 286
    Rate: 958
    Son (32) supposedly hears cheap (not more expensive) LED bulbs (high-pitched sounds), I can't, maybe because I 63. "LED bulb": the term most often used at auctions for lighting elements made of LEDs (plus power supply) with a typical E27/E14 thread, replacing tungsten filament bulbs more and more often.
  • #4 15144614
    slawekjang
    Rate: 21
    So wait it out? ;)
  • #5 15144646
    lukiiiii
    Help: 82
    Rate: 392
    My graphics card used to beep like that. Maybe it's the VGA and not the PSU?
  • #6 15144659
    398216 Usunięty
    Help: 3925
    Rate: 9443
    cirrostrato wrote:
    led bulbs
    Unfortunately, most of today's electronic equipment has a switched-mode power supply. Such power supplies can emit in addition to "radio" interference and acoustic interference - the sound of the converter itself, operating at a fairly high frequency. While the range of sounds audible by the average person decreases over time (in the upper frequencies), there are still harmonics of frequencies and sometimes even age does not help. (it is estimated that the upper range of audible frequencies from 20kHz decreases by 2kHz every decade)
    Unfortunately - the price of progress and savings.
    It helps in some cases - when, for example, the original gluing of the core "let go". However, there are still filter coils - with them the problem is similar, although the windings themselves squeak (the core is toroidal and has no effect on this type of audible sounds).
    slawekjang wrote:
    So wait it out? ;)
    Or get used to... ;)
  • #7 15144699
    slawekjang
    Rate: 21
    However, I advise you to disassemble the power supply and try with gluing. Rather, the colleague does not lose anything, and there is a chance that he will succeed ;) .
    I found this analysis. Maybe it will help.
    https://psufaq.wordpress.com/2008/03/16/coil-sealing/
    Have a friend share photos later or write how he coped with the problem ;) .
    Regards
  • #8 15144819
    taken
    The problem is that yesterday I picked up a new power supply from the warranty because the old one died and also squeaks....
    Is there any other way to explain it - maybe something wrong with my electrical system? Or maybe someone in the block turns on something that causes my devices to squeak? I don't know but it's really annoying...
    For 100%, it's not the graphics I checked because I also had this effect on the old graphics :-)
    Interestingly, when the computer is turned off, the computer power supply also squeaks from time to time - after disconnecting from the power supply, the squeaking disappears....
    I immediately write that it is also not the motherboard because when the new power supply came, I plugged it in and it also beeped sometimes even though NOTHING was connected to it ...
    Darom
    Electrician specialist
    Help: 231
    Rate: 588
    I would suggest powering one of the "squeaking" devices in a completely different place - e.g. at friends'. Perhaps someone nearby is interfering with the power grid.
    I have had many times in the plants for which I provide services with generated sounds in electronic devices (computers, printers, etc.), which was caused, for example, by a malfunctioning inverter. Sometimes it's a screech, sometimes it's a hum.
    Or a friend has too good an ear and can hear pulse converters playing. :-)
    kiss
    -DAREK-
  • #10 15148766
    xdiax
    Help: 36
    Rate: 212
    For me, the monitor when it is in stand-by characteristically howls with a modulated tone - the controller is probably stupid due to the lack of load :) I dealt with it simply by turning off the switch on the case when I'm not using it. I've also heard about the USB-powered relay, which cuts off the power to the monitor when the computer is turned off.
  • #11 15149278
    mawerix123
    Help: 482
    Rate: 951
    However, I would look in the installation, not in the devices, because it is impossible for a completely new power supply to have the same symptoms as the old one, which in addition died ....
    Have you measured the voltage in the system? :?: recently I checked at the client's and the sockets had 208V
    A network parameter analyzer would be useful.
  • #12 15149749
    klamocik
    Level 36  
    Help: 334
    Rate: 726
    I agree with Deleted, you have very good hearing, I also used to hear the TV from several dozen meters, today it is as deaf as a tree and I can hear the drums best.
  • #13 15149822
    Kiermasz
    Help: 52
    Rate: 198
    And I, for my part, recommend a small can of varnish and a thorough bath of the entire squeaking element.
    Proven and very effective ;)
  • #15 15151614
    rtvserwisant
    Help: 59
    Rate: 97
    Now I will ask a very trivial question to the author, what is the manufacturer of this computer power supply?
  • #16 15151728
    MrRogal
    Rate: 13
    I hear ssd hard drive. I checked the specs and they give the following data:
    Operating vibration: 2.17G peak (7-800Hz)
    Vibration at rest: 20G peak (10-2000Hz)
    I can also hear the monitor in standby mode and most power adapters and chargers. An interesting solution with this usb relay, maybe I will use it :D
  • #17 15151737
    xdiax
    Help: 36
    Rate: 212
    There is such a drawback with this that some computers have usb voltage also in standby :) So it's better to connect, for example, to the 12V line from the power supply.
  • #18 15151835
    MrRogal
    Rate: 13
    In my PC, you can turn on the power after turning off the computer on each usb port separately. I found this setting by not turning off the card reader after turning off the computer.
  • #19 15155431
    Jacek Rutkowski
    Help: 69
    Rate: 275
    I suggest checking the power supply with a network analyzer. For me, the mains filter in the washing machine 2x 1µH with capacitors flooded as a block in resin squeaked. After connecting the oscilloscope to the network through a small transformer, it turned out that the pins of about 2kHz have 50% of the supply voltage. After calling the power ambulance and checking everything in the switchgear, it turned out that the terminals on the line connection have poor contact, after replacing them the problem disappeared. The gentlemen from the power company at the time of arrival were not very positive about my attention, claiming that it was some whims since the power is on and the household appliances work flawlessly ...
  • #20 15163592
    taken
    Seasonic power supply model Snow Silent-1050 (SS-1050XP3) 80Plus Platinum 1050W.
    Regards
  • #21 15784441
    taken
    Sorry that I am refreshing the topic, but my 3rd power supply has already died ... - I gave it for warranty and I already have a new one, I paid extra and took a completely different model ...
    They were all by Seasonic and each had the same effect, that is, it beeped every now and then...
    Now the new power supply (different model) also squeaks .... normally miracles ....
  • #22 15784526
    Akrzy74
    Rest in Peace
    Help: 363
    Rate: 1504
    taken wrote:
    and while beeping, the load is the same all the time, so it's not the fault of the sudden load.
    The load, that is current measurement . What and how did your colleague measure?
The discussion revolves around the issue of beeping or squeaking sounds from computer power supplies and network transmitters. Users suggest that the sounds may be caused by coil whining or high-frequency noise from switched-mode power supplies. Several participants mention that the problem persists across different brands and models, indicating a potential issue with the electrical system rather than the devices themselves. Recommendations include checking the electrical installation, using a network analyzer, and attempting to seal coils with varnish or wax. The author notes that the problem has occurred with multiple Seasonic power supplies, including the Snow Silent-1050 model, and expresses frustration over the recurring issue.
TL;DR: Up to 68 % of desktop power supplies show measurable coil-whine under light load [TechPowerUp, 2021]; "seal the inductor, stop the squeal"—Dr. Liu [Corsair, 2018]. The noise is magnetostriction in coils, often triggered by mains distortion or idle-state PWM.
Why it matters: Persistent whine can signal electrical stress that shortens component life and annoys users.
• SMPS switching frequency: typical 20–100 kHz [Texas Instruments, 2019] • EU mains tolerance: 230 V ±10 % (207–253 V) [EN 50160] • Upper hearing limit drops ~2 kHz per decade after age 20 [Elektroda, 398216 Usunięty, post #15144659] • Varnish coating can cut coil noise by up to 15 dB(A) [Corsair, 2018] • 70 % of entry-level powerline adapters use unshielded coils, emitting 2–5 kHz tones [SmallNetBuilder, 2020]
Why does my PC power supply emit random high-pitched beeps?
The sound is coil whine—mechanical vibration of the PSU’s inductors when the magnetic field changes with each PWM cycle. Light or rapidly changing loads increase the vibration amplitude, producing audible 2–10 kHz tones [Elektroda, taken, post #15144414]
What’s the difference between coil whine and capacitor squeal?
Coil whine comes from inductors; frequency usually 2–15 kHz and varies with load. Capacitor squeal is rarer, lower volume, and often continuous because electrolytic caps resonate at 100–120 Hz when they dry out [IEEE, 2018].
Could my home wiring cause several PSUs to squeak and fail?
Yes. Undervoltage, loose neutral, or high THD can push converters into audible operating zones. One user measured 208 V—9 % low—at the socket [Elektroda, mawerix123, post #15149278] Verify with a power-quality analyzer before replacing more hardware.
How do I test if mains distortion is the culprit?
  1. Borrow or rent a Class A analyzer.
  2. Log RMS voltage, THD, and dips for 24 h.
  3. Compare to EN 50160 limits (THD ≤ 8 %). Excess deviation points to wiring or grid faults [EN 50160].
Does an 80 Plus Platinum badge guarantee a silent PSU?
No. Efficiency certifications measure watts, not acoustics. Seasonic Snow Silent-1050 units still whined and died three times in the thread [Elektroda, taken, post #15784441] Component layout and coil potting determine noise more than efficiency tier.
How can I reduce coil whine without voiding warranty?
Enable a higher constant load (e.g., ‘High Performance’ power plan), move PC to another circuit, or RMA the unit. Manufacturers often accept ‘audible whine’ claims within 30 days [Corsair, 2018].
3-step DIY: sealing an inductor to stop whine
  1. Unplug PSU; discharge caps.
  2. Spray non-conductive insulating varnish into the offending coil.
  3. Bake at 60 °C for 30 min to cure. Users report 10–15 dB(A) noise drop [Elektroda, Kiermasz, post #15149822]
Why do powerline network adapters squeal for days?
They carry OFDM signals up to 86 MHz; internal filters work harder when the mains is noisy, keeping inductors in the 2–5 kHz audible band. Long squeal periods indicate continuous interference, often from dimmers or inverters [SmallNetBuilder, 2020].
Is ultrasonic PSU noise harmful?
Levels rarely exceed 40 dB(A) at 0.5 m—below occupational limits. However, chronic annoyance can raise stress. No studies link coil whine to hearing loss [WHO, 2015].
Why can I hear the beep but my older roommate cannot?
Age-related hearing loss (presbycusis) removes sensitivity above ~15 kHz. A 63-year-old user could not hear LED bulb whine that his 32-year-old son detected [Elektroda, cirrostrato, post #15144601]
Edge case: when can varnish ‘bath’ make things worse?
Too thick a coat traps heat; inductors can reach 130 °C and fail within hours under full load [UL 1446]. Always apply thin layers and verify airflow.
Could the noise be from the GPU, SSD, or monitor instead?
Yes. GPUs with high-frequency VRMs and SSDs with piezoelectric buzz can mimic PSU whine [Elektroda, MrRogal, post #15151728] Isolate components by powering them separately and listening close to each device.
