Fiat panda 2 2006 - No parking lights, power consumption error b1015 b1008
slawarek 7584 2
  • Body module wiring fault suspected in parking lights circuit
    #1 16586740
    slawarek
    Rate: 212
    I have a panda from 2006 and there are no parking lights, in addition, the backlight of the heating knobs consumes electricity, which works all the time. Fes shows that the steering switch is operational, the others too. The errors that boody registers are b1015 plate lighting error and b1008 front parking light control. It is not possible to control the parking program and the board with the other elements. as I corrected it to the factory, I checked the power consumption of the light bulbs and they are normal, there is no leakage of electricity to other cables. I checked the body module and from the black PM plug the cable (the one from the lighting knob for the heating) red and yellow pin9 spreads to the other plugs, the relays are good, they do not have a short circuit. Anyone had such a problem? I don't have a pattern for panda lights, so I'm looking for it in the dark. Replace the module? In or else to look for the cause?
  • #2 16586766
    czareqpl
    Help: 196
    Rate: 580
    slawarek wrote:
    I have a 2006 panda and no parking lights
    If there is none, there is no ... Too bad, probably such a model and that's it.
    But seriously, remove the relay controlling the parking lots and manually close the executive contact. If the bulbs light up, it means that the problem is on the control side and the control cables need to be x-rayed.
  • Pin 9 circuit distribution needed for parking lights
    #3 16586947
    slawarek
    Rate: 212
    I have a diagram and it matches what I checked.
    Comfort is with the control of the circuits, so the control is out of the question and the computer sees the signals correctly from the switches. I think that the current consumption of the airflow knobs is more important and the computer is blocking the activation of the parking lot.
    I am interested in what circuits are distributed from pin 9 (black flat plug as PM black) is highlighting because there is no schematic anymore, maybe someone has such a piece of the diagram.
