Fiat Panda 1.1. 2009 interpretation of the results of diagnostics.
guma74 3003 2
  • #1 18726024
    guma74
    Hello everyone and I want to warn you in advance that I am a layman in the subject and I do not know diagnostic measurements. In my Panda 1.1 January 2009, I noticed that it was waving at idle and choking when shifting gears. The first thing I did was replace the candles and cables, clean the throttle and stepper motor, and the cable connectors at the throttle, but it did not help. Then I cleared all the pins on the ECU and still nothing. I got the interface and read the errors 0130- Lambda sensor circuit (cylinder block No. 1, probe 1) malfunction. I deleted this error but the situation has not changed. Despite the fact that I do not know the parameters, I tried to diagnose the probe in the ScanMaster program. Can anyone tell me what these readings mean and are they correct?
    Separated from the topic: Welcome topic for new users - introduce yourself
    by ArturAVS on 29 May 2020 15:08
    • Fiat Panda 1.1. 2009 interpretation of the results of diagnostics. IMG_20200529_120045[1].jpg (6.37 MB) You must be logged in to download this attachment.
    • Fiat Panda 1.1. 2009 interpretation of the results of diagnostics. IMG_20200528_142344[1].jpg (4.54 MB) You must be logged in to download this attachment.
    • Fiat Panda 1.1. 2009 interpretation of the results of diagnostics. IMG_20200528_120310[1].jpg (5.98 MB) You must be logged in to download this attachment.
  • #2 18726220
    kortyleski
    Help: 957
    Rate: 3847
    This probe error once briefly occurred and was stored. Don't worry about it.
  • #3 18726938
    guma74
    ok. but the next graph of probe 2 is probably not very correct.
