Tp-Link TL-Wn722N Wireless USB Adapter Connection to Hyundai Smart TV: USB to RJ45 Adapter
Bartek0041 8619 3
  • #3 16587670
    speedy9
    Helpful for users
    Help: 1233
    Rate: 2425
    If a TV set allows you to connect a WiFi network card via USB, it must be a dedicated network card from the TV manufacturer. Inserting any card will certainly not work.
    If you search the Internet, you will find threads on forums in which modifications of some network cards are described to work in a given TV model. However, it is usually quite difficult to buy the correct card model that is suitable for this. In addition, the TV manufacturer had to implement USB WiFi card support, and yes, on a TV in which it did not provide for it (check the manual), it cannot be done.
  • #4 16587673
    Bartek0041
    The TV model is Fl40211 Smart. The original card costs PLN 60, so just give the TP link or leave it for the future?
