PARKSIDE PKO 400 B2 50L - The PARKSIDE compressor does not start.
simbamat 11064 4
  • #1 16588859
    simbamat
    Rate: 10
    I have a problem with the PARKSIDE PKO 400 B2, 50l, 2.4 kW compressor:
    after about 30 minutes of work with interruptions while pumping air, the engine made a strange sound and stopped pumping.
    I tried to disconnect and connect to the network several times - to no avail.
    After a few hours break, it still does not start.
    It makes no sound.
    The compressor is no longer under warranty.
    It has been used sporadically so far.
    I am asking for help what may be the reason of failure.
    Thanks.
  • #2 16588864
    stanislaw1954
    Help: 2013
    Rate: 4663
    There are no fairies in the forum.
    There is a lot to check: power supply, control, motor itself.
  • #3 16592888
    nikusert
    Help: 699
    Rate: 1754
    First, check whether power is supplied to the pressure switch (pressure switch), then whether the air is turned on (if the contacts are shorting), and the motor is energized. If so, the motor winding should be measured for winding breaks.
    ekrzych
    Check if you have a thermic reset button on the engine. I met with one in another compressor. The motor itself, if there is no breakdown to the housing or a break in the windings, you can power it for a short time, bypassing the pressure switch. If you move you can be sure that the pressure switch is damaged. Just don't use it in such a way, because you will make a bauble ;) .
  • #5 16621896
    simbamat
    Rate: 10
    Thanks for the tip.
    The compressor works.
