[Solved] Parkside Screwdriver Battery Issues: 18V Not Charging, LED Blinks, No Power Detected
noidemm 81297 9
Why does my 18V Parkside screwdriver stop working even though the battery meter shows voltage, the charger does not detect the pack, and the LED only blinks briefly when I switch it on?
The battery was discharged below the charger’s detection threshold, so the charger did not recognize it, and the screwdriver’s undervoltage protection shut it down and only made the LED blink [#16951665] The cells were reported as good, so the problem was not a bad cell but an overdischarged pack [#16951665] The pack could be revived by briefly boosting it with an external battery so its voltage rose enough for the charger to see it, after which normal charging started [#16951665] Another user noted that a weak or empty pack may need an external voltage source or a stronger charger/current source because the charger otherwise never wakes up [#17290424] It was also suggested to test the battery under load, for example with two 21 W car bulbs, and to check the individual cells if needed [#16939738][#16950860]
  • #1 16939721
    noidemm
    Rate: 254
    One day the screwdriver stopped working. I put the battery in the charger and does not detect anything. The meter on the battery shows the total charge. When you try to turn on the screwdriver, only the diode from the screwdriver lightly blinks (from the backlight of the work place) and that's it. It seems to me that the battery has no power, and how much the meter has 18v or charged. Measured without load.
  • #2 16939738
    avatar
    Level 36  
    Help: 160
    Rate: 417
    It may try to charge the batteries with some known load and see if the appropriate current appears. I think that 2 bulbs for 21W car will be ok for this experiment.
  • #3 16939787
    marek2145
    The charging voltage should be approx. 5% higher than the nominal value of the battery. If it is smaller or equal the loading will be incomplete although the indicator will show full
  • #4 16939798
    noidemm
    Rate: 254
    I unscrew the battery, connected it to the screwdriver and to the voltmeter. When the 18v screwdriver is turned off, when it is turned on, the current drops to 0. In the battery casing a piece of the casing is burned out (this way it looks like something would be heating up). Below photos.
    Parkside Screwdriver Battery Issues: 18V Not Charging, LED Blinks, No Power Detected Parkside Screwdriver Battery Issues: 18V Not Charging, LED Blinks, No Power Detected Parkside Screwdriver Battery Issues: 18V Not Charging, LED Blinks, No Power Detected
  • #5 16939827
    avatar
    Level 36  
    Help: 160
    Rate: 417
    it looks like a bad injection mold from this part of the battery housing. I suggest you give away for guarantees (ps you can not take apart the equipment in PL because it's probably an offense like no longer a crime).
  • #6 16939853
    noidemm
    Rate: 254
    It's probably out of warranty, I think. I need to see. And the badly cast or burnt one is above these elements.
    romeo743
    Rate: 15
    And you tried to measure the voltage on individual links?
    Maybe some link is damaged and the protection works?
  • #8 16951665
    noidemm
    Rate: 254
    The problem was solved, namely all links were good. The battery somehow discharged below the critical point to such an extent that the charger did not see it. The screwdriver itself switched on the safety mode and turned off due to too low voltage. I plugged a small AA battery into the battery and connected it via the charger (this way the battery current jumped to 19v). The charger detects the battery and recharges it. The battery has come back to life. I close the subject.
  • #9 17290345
    dzimi
    Help: 822
    Rate: 1286
    At the request of the author of the topic - unlock.
  • Precharge charger with 10–11 V to wake battery detection
    #10 17290424
    Vendeur
    Rate: 23
    I asked for the topic to be unlocked to add photos if anyone needed.
    The puzzling thing about this Parkside set is that since the screwdriver has a protection and turns off when the battery voltage is low, it does it at the wrong time, since the charger is unable to see the battery. Basically, the problem here is the charger, which, for senseless reasons, does not see it at all at low battery voltage.
    I couldn't save my colleague's method above, i.e. I plugged the external battery into the circuit, and exactly put the wires inside the battery plug. Since the charger was supposed to detect the voltage, it supposedly should start, especially since my external battery was a 16340 and had a voltage of 4.1V, which is much more than 1.5V with AA. But after connecting the charger turned off the red diode, something was ticking and then the red one turned on again.
    I managed a different way. For this purpose, you need either an ordinary car rectifier that will be able to provide a stronger current, or a modern car charger + some gel battery to start it at all, because it does not provide any voltage by itself. Fortunately, I had a charger + some old gel battery with a voltage of 1V ... So I connected the gel to the car charger and connected the wires from the charger's battery plug. The charging voltage fluctuated between 10-11V. At the beginning, after a while, the green diode turned on and after disconnecting it did not want to go out ... On the second attempt, I combined with shorter times of connecting the wires to the gel charger and it worked, the charger surprised and the green diode began to flash, i.e. the battery charging began.
    Pictures below.
    Information yet. The cells are hopeless, unbranded, capacity 1300 ... So if someone wants to play with detaching the plates and re-soldering the cells, you can buy 5 pcs for PLN 20 for PLN 100, the best cells on the market with a capacity of 3500mAh. In this way, we would have a battery 3 times as good as the original.
The discussion revolves around issues with a Parkside 18V screwdriver that fails to charge and shows no power, indicated by a blinking LED. Users suggest testing the battery under load and measuring the charging voltage, which should exceed the nominal value for proper charging. The author discovers a burnt section in the battery casing and suspects a malfunction. After troubleshooting, it is revealed that the battery discharged below a critical voltage, preventing the charger from detecting it. A workaround involved connecting a small AA battery to jumpstart the charging process, successfully reviving the battery. The conversation highlights the charger’s inability to recognize low-voltage batteries and discusses various methods to address the issue.
