[Solved] Amica PI6511SF INARI Induction Hob: Error E2 Flashing in All Fields - Troubleshooting & Solutions
macieja 23958 4
  • #1 16588893
    macieja
    Help: 78
    Rate: 266
    Hello colleagues.
    I have a problem with the Amica PI6511SF INARI induction hob. After the vacation I attached the disc and E 2 flashes alternately in all fields. I would add that it was operational before the vacation. Where to look for a fault?
    Thanks for the hints.
  • #3 16592843
    macieja
    Help: 78
    Rate: 266
    E 2 poor cooling! As I wrote, the album went 2 years without any problems. After 2 weeks of leave I enclose and here on all fields E 2. I will point out that ventilation is ok. The fans in the plate clean ducts behind the cabinet.
  • #4 16907977
    SirBlood
    In the E2 manual it is a problem with power supply and not with cooling.
  • #5 16908499
    macieja
    Help: 78
    Rate: 266
    The relay "burned contacts" was damaged, after being replaced with a new one the topic to close came to life.
