Car Radio Spontaneous Switching On/Off: Causes, Clock Backlight & Direction Indicators Factors
Crever 26634 6
  • #1 16589017
    Crever
    Hello!
    Another problem that describes in this forum which is the frequent spontaneous switching off of the car radio while driving (turns off when gently moving, e.g. half couplings and at speeds close to 50km / h and 100km / h).
    In addition, I describe the situation when I installed the radio from a friend and when completely mounted to the car turned off the clock backlight (as I took out half the radio backlight came back) and when turning on the direction indicators.
    The radio also turns off when you stop the vehicle although it doesn't always behave like that.
  • #2 16589044
    SERVICE-AV
    Help: 728
    Rate: 899
    Time to check the wiring in the car :)
  • #3 16590285
    Crever
    Any tips on how to get started?
    I've never done that
  • #4 16590323
    398216 Usunięty
    Help: 3925
    Rate: 9453
    Pull the radio out - is it inserted or permanently in the panel? If slip-in (sometimes you need "unclogs" to unlock them - in most car service stations dealing with radio installation) check the connection block. She's probably loose.
  • #5 16590328
    kkknc
    Help: 1916
    Rate: 6720
    The radio is raining just as well.
  • #6 16590543
    398216 Usunięty
    Help: 3925
    Rate: 9453
    Of course, non-power contact is more suited to such symptoms:
    Crever wrote:
    disengages when gently moving, e.g. half couplings and at speeds close to 50km / h and 100km / h).
  • #7 16590720
    Crever
    Thank you in advance for your response :)
    An additional symptom is the blinking of the backlight of the waveform when turning on the direction and emergency indicators.
    I called the previous owner and said it could be a mass fault.
The discussion revolves around a car radio that frequently switches off while driving, particularly during gentle movements and at speeds of 50km/h and 100km/h. Users suggest checking the wiring and connections, as a loose connection could be the cause. The author notes that the radio's clock backlight turns off when the radio is fully mounted, but returns when the radio is removed. Additionally, the radio turns off when the vehicle stops, although this behavior is inconsistent. There are also reports of the waveform backlight blinking when the direction and emergency indicators are activated, leading to speculation about a possible grounding issue.
