Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence
orzech1988 51045 13
How can I diagnose recurring P0420 on a Citroen C3 1.4 petrol/LPG, and which lambda probe or exhaust-related fault should I check?
Check the rear lambda probe and the exhaust system around the catalyst, because the front probe controls mixture while the rear probe is diagnostic; if the rear signal mirrors the front one, the cause is usually a faulty rear probe, a leaking exhaust joint, a damaged catalyst housing, or a secondary-air-system fault, especially since P0491 also appears [#16593133] [#16594058] [#16614727] The front probe should swing roughly between 100 mV and 900 mV, while a healthy post-catalyst probe should sit around 400–600 mV; in the posted data the rear sensor follows the front too closely, which points to a problem [#16594765] Check the heater circuit on the rear probe, measure the resistance between the two white wires, and verify voltage at the connector; the reported 7.6 Ω was considered acceptable, and if the connectors are identical you can swap the probes to rule out a sensor fault [#16594765] [#16595102] Also inspect the catalyst-to-manifold joint and gasket for small leaks, and reseal it with paste/new gasket if needed, because fresh air entering the exhaust can make the rear probe look wrong even when the catalyst itself is OK [#16593133] [#16595102] If the catalyst housing is cracked or burst from heat, that can also let in air and trigger P0420 again [#16594058]
  • Questions about oxygen sensor diagnosis for P0420
    #1 16592945
    orzech1988
    Hello to all Electrode Members.
    This is my first post, due to the fact that I can not find an answer to my questions.
    The fault concerns the car:
    Citroen C3 2002 engine 1.4 petrol (KFV)
    Error P0420 - catalyst aging.
    Short description.
    Half a year ago in December 2016, the "check engine" indicator appeared in my car. After some time I connected the DAIGBOX - LEXIA software and read the error code (I will add that the burning increased when the light started to glow).
    Then I went to the mechanic to replace the catalyst, which has already worn out.
    After replacing and erasing the error, I had peace. Burning has returned to normal. Nothing came and the engine was running normally.
    About a month ago (June 2017) the control popped out again, I plugged LEXIA and the same error ... This time I went to another mechanic, because I was surprised that the catalyst was broken again.
    The mechanic, after inserting the probe into the exhaust pipe and examining the exhaust gases, found that the catalytic converter was operational and ordered replacing the spark plugs and then the oxygen sensor behind the catalytic converter if the replacement of the candles did not help.
    After taking out the candles, you could see signs of wear - they were probably ill-chosen. After screwing in and resetting the fault, the engine light comes on again. I read the code - the same error P0420 - catalyst consumption.
    And now the questions to you:
    1. Is the probe exchangeable?
    2. If so which one?
    3. Please indicate what indications should appear on the probes? What voltage?
    4. What probe to buy? What brand?
    Attached I will add photos, (also error P0491, which from time to time appears) and videos from the engine work on gasoline and gas.
    Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence
    Video 1: Gas work
    ********** ********** above w.you tube.com/watch?v=3gZewLPoV8A
    Video 2: Working on gasoline
    ********** ********** above w.you tube.com/watch?v=AHC28WWvOWU
    Please delete "**********" in the links to the videos, because I can not directly paste them.
    Exhaust leak at catalyst joint may trigger P0420
    #2 16593133
  • #3 16593944
    orzech1988
    prosty_01 wrote:
    Maybe it is some leakage at the connection of the catalyst with the exhaust manifold ... Was the gasket replaced with the catalyst? It would be good to unscrew the catalyst and connect the joint with a paste to seal the exhaust system, previously cleaning the contact surfaces of both components.
    Honestly, I have no idea if the catalyst was exchanged according to the art and whether the gasket was replaced. I left the car with a mechanic who had good reviews, and if I did it well, I do not know. For half a year it was all right.
    I will try to see the connection you mentioned in a short time. Perhaps there is a leak there.
    Thank you for your help.
    Any additional suggestions from forum members are welcome.
    sebap
    Help: 538
    Rate: 1083
    Record the film from the work of the probes and upload here.
  • #6 16594679
    orzech1988
    I tried to upload, but it only takes a few seconds ...
    And the movie has been reduced from 101 MB to about 22 MB.
    In the first post at the very end I gave youtube links. You only have to delete the stars in the link, otherwise I could not paste.
    prosty_01 wrote:
    I had a case with a peugeot 208 1,2. The error is identical, the operation of the probe behind the catalyst is almost identical to that before, i.e. either the second one is freaking out or the catalyst is damaged. After removing the cover, it turned out that the catalyst housing was bursting with temperature and fresh air was supplied to the exhaust gases (and the lambda probe is responsible for the measurement of oxygen in the exhaust gases), hence the anomalies on the second probe ...
    It is also possible to exclude damage to the probe, it is only strange that the problem has disappeared for half a year.
    It may have been that the catalyst was previously damaged, after the replacement of the new one, in turn, the probe broke. Unhappiness goes in pairs.
    But for the moment I am inclined to this "left" air and some leakage.
  • #8 16595023
    orzech1988
    prosty_01 wrote:
    The latter certainly does not work properly; check resistance of the heater and voltage on the plug.
    Previously, I sent the values of correct indications
    It's like this: I got tired of the jack and pushed under the car.
    Below is a pictorial photo of combining a kata with a collector. It looks like the exchange is okay, I have heard nothing, and I have not felt any leaks. In the pictures you can see a mass, perhaps the sealer you mentioned.
    I did not see any cracks or anything on the catalytic converter and in the vicinity. I shot the photo probe as in the picture. It seems to be a bit tired.
    but "up to shore ..."
    I measured the resistance of the heater, i.e. unplugged the plug and measured the resistance between the two white wires. I am not an electronics or mechanic, so I attach pictures as I set up the Multimeter. The resistance was 7.6 Oma, if I read correctly. Should it ?? 15 -30 ohms?
    So it means that the probe is 99% damaged?
    Regarding the voltage, I measured it: on the motor switched on the second part of the plug I connected to the negative pole of the battery and the result was on one of the cables above 14 V, also the voltage is, if I understand correctly.
    The conclusion is as follows: replacing the Lambda probe, do I understand correctly?
    Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence Citroen C3 1.4 Gasoline + LPG: Catalytic Converter Aging - Error P0420 Reoccurrence
    prosty_01 wrote:
    By the way, the catalyst is damaged when gasoline enters the exhaust system along with the exhaust gas; several reasons; pours the injection, unburnt fuel / air mixture, etc. In the exhaust gas you can feel the petrol.
    I wonder if sometimes it is not the fault of the second probe from the beginning, and the new catalyst improved slightly the voltage indication sent as a signal to the ECU.
    This knowledge will also be useful in the future.
    It is very possible that you are right and the catalyst was fairly efficient.
    I'll see how I change the probe and leave the whole tank. Will the error no longer jump out.
  • #9 16595102
  • Asking what the marked PDF components do
    #10 16598784
    orzech1988
    Probe replaced with new one, erased errors ...
    Now I drive and see if the error will appear again or not.
    Attached photos and video.
    MOVIE:
    please delete "****" stars
    www. ****** ****** youtube. com / watch? v = pxYNTG_yfXQ
    I still have a question, unrelated to the topic, and I do not want to throw it elsewhere.
    What are the elements marked on the picture (PDF), what are they used for, what are they responsible for?
    Thank you in advance for your answer.
    • co to jest.pdf (1.06 MB) You must be logged in to download this attachment.
  • #12 16600516
    orzech1988
    prosty_01 wrote:
    This is a secondary air system to oxygenate the exhaust
    Thanks for your quick response! It's good to know what this equipment is, because I never knew what it was.
  • #13 16614648
    orzech1988
    I traveled a bit ... the error jumped again, despite the replacement of the probe behind the collector. Attached photos.
    In addition, I was to measure the composition of the exhaust of the photo I also paste.
    Any ideas what is wrong? How to fix the fault? Do you run the system and drive as it is?
    Greetings.
    When it comes to photos from the exhaust gas analysis, this is the first picture about exhaust gas on gasoline. The second photo shows the analysis of LPG combustion.
  • #14 16614727
The discussion revolves around a recurring P0420 error code related to catalytic converter aging in a 2002 Citroen C3 with a 1.4 petrol engine. The user initially replaced the catalyst after the check engine light illuminated, which temporarily resolved the issue. However, the error reappeared six months later, prompting further investigation. Forum members suggested potential causes, including exhaust leaks, lambda probe malfunctions, and secondary air system issues. The user replaced the lambda probe but continued to experience the error. Recommendations included checking for exhaust leaks, analyzing probe readings, and addressing secondary air system faults before concluding the catalyst's condition.
