[Solved] Pacifica P0420 Error: Clogged Catalyst Troubleshooting - Can it be Cut Safely & Alternatives
farmer2020 111549 9
Can I cut out the catalytic converter on a car with P0420, and what alternatives are there instead of buying a new one?
P0420 does not mean the catalyst is clogged; it means the engine controller sees the same exhaust composition before and after the catalytic converter, and if it were really blocked the car would have very poor power and run hot. Cutting it out or deleting the fault from the ECU is not a sensible fix, because the rear oxygen sensor will still report low catalyst efficiency and normal diagnostics can be compromised [#16698723][#16699206][#16698332] The practical options mentioned are a new catalytic converter or a second lambda probe emulator [#16698062][#16699772] One user also reported that replacing the rear probe solved a similar case [#17002603]
  • #1 16697804
    farmer2020
    Rate: 37
    Hello, the check lamp went on and the error P0420 appeared, the previous owner said that he had a problem with the clogged catalyst and I think that the same is happening now. Therefore, I have a question whether you can cut the catalyst without consequences for the car, and maybe someone has other ideas than to buy a new catalyst.
  • #2 16698001
    rrr86
    Rate: 17
    Hello, I suggest you remove this error from the table in the controller and possibly open the catalyst or replace it with a jet pump.
  • #3 16698062
  • #4 16698332
    kortyleski
    Help: 957
    Rate: 3860
    rrr86 wrote:
    Hello, I suggest you remove the error from the table in the driver
    Table modifications lead only to the fact that later normal diagnostics will become impossible and the client with the fault will be transported from the workshop to the workshop.
  • #5 16698723
    grala1
    VAG group specialist
    Help: 1496
    Rate: 5053
    This error does not concern the catalyst clogging only the lack of its operation. The engine controller sees identical composition of exhaust gases before and after the catalytic converter.
    If you had a clogged catalyst, it would not be a mistake and the car would barely go.
    A colleague of "Poverty with misery" wrote what can be done.
    There are no other sensible possibilities.
  • #6 16699077
    jacek0503
    Help: 28
    Rate: 175
    I warmly welcome. I was interested in the subject because I had a similar case myself. The engine light went on, error p420, opel astra h 2007 1.6 105 km lpg. I deleted the error with the software and has not appeared since then - 2 weeks Therefore, I have a question to my friend who is playing the game - I do not really understand what the colleague means - "This error does not concern the clogging of the catalyst but the lack of its operation." The engine controller sees identical composition of exhaust gases before and after the catalytic converter.
    If you had a clogged catalyst, that would not be a mistake and the car would barely go "- as far as I know the catalyst error comes either from the clogged catalyst or from the burned (empty). You can also take the wrong operation of the lambda probe behind the catalytic converter (check how oscillates.) From what I understand, there are two options:
    1. New catalyst - or not burnt and not clogged
    2. The orchard emulator behind the catalyst - although I read that it does not always help.
    Of course, I will not mention such miracles as drilling a hole in a catalytic converter, etc.
    My colleague, a mechanic, told me that this is happening in time and he advised me to "chase" the car on the highway and it will be ok. What's the problem with this?
  • #7 16699206
    grala1
    Help: 1496
    Rate: 5053
    If the probe did not work then you would have a mistake about it, here the problem is that the driver sees the same exhaust composition before and after the catalytic converter.
    More than once I had contact with a clogged catalyst or burned out, and this error always concerned the spent one.
    If the catalyst is blocked, the engine has no power, the combustion rises and there is silence in the back because the silencer just smokes exhaust fumes.
    You want to look at the oscillation of the probe, compare it with the oscillation from the first probe (if the first one is not broadband).
  • #8 16699772
  • #9 16699925
    farmer2020
    Rate: 37
    Poverty and misery can be provided in some other way without being written here
  • #10 17002603
    farmer2020
    Rate: 37
    It helped to replace the probe with a new one only a little better than the Chinese one, I imported from the US, cost about PLN 200 with shipment, customs and tax.
The discussion revolves around the P0420 error code, indicating potential issues with the catalytic converter in a Pacifica vehicle. Users share insights on troubleshooting, suggesting that the error may not necessarily stem from a clogged catalyst but rather from a lack of its operation, as the engine control unit detects identical exhaust gas compositions before and after the converter. Recommendations include replacing the catalytic converter, using an emulator for the second oxygen sensor, or checking the lambda probe's functionality. Some participants caution against modifying the engine control table, as it could complicate future diagnostics. A user mentions successfully resolving a similar issue by replacing the oxygen sensor.
