premiumBox + wifi - HDMI, HDCP signal is switched to SCART after turning off the
Andrzej Kmicic 4596 6
  • #1 16595587
    Andrzej Kmicic
    Rate: 9
    I have a few doubts and questions related to the NC + PremiumBox + WiFi decoder, which I was forced to block the previous Philips PVR decoder.
    I have a bedroom through the wall and connected (I always had) TV via AV via SCART - Cinch AV cable. And everything was ok. Currently, after turning off the TV in the main room (HDMI), the decoder is blocked and displays a SCART board about the harmfulness of copying. I am not copying anything? And when I do not hear something and it shines, I can't sleep. Hence my problem.
    1. Please explain to me what this copying and relation with excluding TV is about ???.
    2. I read that you can get around it by buying a not cheap splitter or an active cable.
    3. What is this security feature, if you just pull out the HDMI plug from the TV and the SCART signal is OK.
    4. The signal dies immediately after inserting the HDMI plug, even when the TV is disconnected from the mains. So it is not an active connection, but a passive one. It is enough to safely disconnect any end, just advise which one? Because if I fan the HDMI plug, this socket will go to hell quickly.
    AK
  • #2 16595602
  • #3 16638031
    Andrzej Kmicic
    Rate: 9
    mihal2002 wrote:
    The decoder software was written this way. Buy yourself an HDMI splitter and that's it.
    I more or less knew that, thanks. But maybe the HDMI cable can be manipulated. Breaking this connection should result in the absence of the OFF signal. But which wire is it in the cable?
    I still do not know how to manipulate it so that the decoder does not "see" turning off the TV. Let me remind you when the TV is completely turned off from the mains, it is the same as when the TV is on. So it is a question of pulling one of the HDMI terminals to the ground ???.
  • #4 16639096
    Polon_us
    Help: 1184
    Rate: 1280
    Before your colleague starts fiddling with HDMI cables, please check the status of the HDMI-CEC or HDMI-Control function / option. Both TV and set-top box.
    Andrzej Kmicic wrote:
    so that the decoder does not "see" the TV off.
    This operation of the decoder suggests that these functions are enabled.
  • #5 16681499
    Andrzej Kmicic
    Rate: 9
    I have not solved the problem, I pull out the HDMI plug, then turn off the TV and then the decoder works on the SCART output. I do not know if it is not a shame not to improve the decoder software? I will order a cheap HDMI splitter and check if it is enough to switch to an unused input before turning off? I'm not closing because someone can find a solution.
  • #6 16685357
    LeDy
    Help: 1990
    Rate: 2938
    How did you not solve? You know how to get around.
  • #7 16865400
    Andrzej Kmicic
    Rate: 9
    The switch helped, although the problem is because I have to switch to an empty place before turning off the TV.
The discussion revolves around issues with the NC+ PremiumBox WiFi decoder, particularly regarding the HDMI and SCART connections. Users report that when the HDMI-connected TV is turned off, the decoder switches to a SCART output displaying a message about copying restrictions, despite not engaging in any copying activities. Solutions proposed include using an HDMI splitter to maintain a connection, checking HDMI-CEC settings on both the TV and decoder, and manipulating the HDMI cable to prevent the decoder from detecting the TV's power state. One user found success by switching to an unused HDMI input before turning off the TV, while others continue to seek a more permanent software solution for the decoder.
