NC + tv decoder LG 42LN5400 - HDCP connection error after turning on the TV
kank 59574 8
  • Recurring HDCP handshake failure between decoder and TV
    #1 15205788
    kank
    Rate: 15
    I have a LG 42LN5400 TV. I have been using the NC + decoder for over a year now and there were no problems.
    Lately daily when I turn on the TV, an information pops up: HDCP copy protection - there was a problem with the HDCP connection
    NC + tv decoder LG 42LN5400 - HDCP connection error after turning on the TV .
    By following the instructions, the tv will NEVER work properly the first time, I have to struggle a few times before I can finally start watching TV.
    It is a bit tiring, especially if your older father or mother is watching TV and they cannot cope with it.
    What could be wrong?
    - The TV set is fairly new
    - nc + decoder
    - connection set-top box - tv via HDMI
    It is strange that once everything was ok and at some point it started to pop up, and the next thing is that finally after some time turning on and off the tv and decoder according to the instructions I go and everything is ok until the next turn off the tv :(
    Please help.
    Thank you in advance.
  • LG 42LN5400 firmware update support and language questions
    #3 15208054
    kank
    Rate: 15
    Ok, I found instructions on how to update, but one sentence bothered me:
    "Software upgrades include device drivers and firmware upgrades for certain models only. Please check the user manual to see if your product supports upgrades."
    Unfortunately, I can't find information about whether my tv supports updates. Secondly, I don't know which soft to download, I don't know, can I break something? Is there Polish or English language? Try with this tv or try to replace the decoder?
  • #4 15208427
    irek6311
    Help: 229
    Rate: 281
    SOFTWARE FILE (VERSION 04.18.06), it is soft for your TV, as for the decoder, you can first try to replace it, as this option will not change anything to update the soft on the TV.
    EDIT:
    mihal2002 wrote:
    You just need to turn on the online update on the TV.
    Often such an update results in the software crashing, it is safer to upload it from a pendrive.
  • #6 15208469
    maksar
    Help: 177
    Rate: 1030
    On what basis. They will check and it works.
    irek6311
    Help: 229
    Rate: 281
    Whether they will replace it depends on the NC + Point, I have it around the corner, so I can easily borrow for an hour to test them, as for TV, there is a Hotline and there you can make sure about the software version, @ they will send the right one and often unavailable on the website ( http://www.lg.com/pl/wsparcie/kontakt-obsluga-klienta).
  • Test decoder first, then install LG firmware 04.18.06
    #8 15208999
    kank
    Rate: 15
    mihal2002 wrote:
    It is enough to turn on the online update on the TV
    How should I do it if I don't have such a function in my model, it is not connected to the internet and there is no wifi receiver?
    Thanks for the advice, I will try the decoder first and then the soft tv.
  • #9 15241222
    kank
    Rate: 15
    Everything works fine. I told my friend about my problem and he advised me to try changing the HDMI cable to another one. It worked. It turns out that it is often worth checking the simplest things first than looking for problems without knowing where.
    I think that the topic can be considered closed.
The discussion revolves around an LG 42LN5400 TV experiencing HDCP connection errors with an NC+ decoder after prolonged use without issues. The user reports that the error appears daily upon turning on the TV, requiring multiple attempts to resolve. Responses suggest that the problem may stem from a recent software update on the decoder, and users recommend checking for firmware updates for the TV. One user successfully resolved the issue by replacing the HDMI cable, highlighting the importance of troubleshooting basic components before seeking more complex solutions. The user plans to first test a different decoder and then consider updating the TV's software if necessary.
