[Solved] NCP-4740SF wifi Premiumbox + - Connection of the set-top box with the HW-H430 So
MAMROCK 5280 19
How can I connect an NCP-4740SF set-top box directly to a Samsung soundbar that has only optical and minijack inputs, when the box outputs audio via SPDIF/HDMI?
Use a digital coaxial S/PDIF-to-optical audio converter between the decoder and the soundbar, because the decoder’s S/PDIF output is the coax/electrical type and the soundbar needs optical input; a direct cinch-to-minijack cable will not work [#16310012] [#16310195] You need a normal CINCH/RCA cable from the decoder to the converter and a TosLink optical cable from the converter to the soundbar [#16310195] If you try the SCART route instead, you still need the proper SCART-RCA adapter/cable, not a simple analog minijack lead [#16314736]
  • #1 16308986
    MAMROCK
    Help: 5
    I was looking for any description of this "problem" on the web - unfortunately I couldn't find it :(
    Namely - I want to directly connect the NC + decoder (Model DB NCP-4740SF wifi Premiumbox +) with my Samsung Soundbar, unfortunately I have a problem with this, because the ecoder has an audio output:
    Dolby Digital (SPDIF and HDMI ), and the Soundbar optical and minjack inputs ...
    I bought an SPDIF (Cinch) -> minijack cable - unfortunately the decoder vs soundbar does not work in combination.
    When connected with the same cable: TV -> soundbar, the sound is ...
    I have no idea what I have to buy in order not to have to turn on the TV to listen to e.g. internet radio.
    I was at the NC + showroom, but the salesperson only told me that many customers have this problem and he doesn't know the solution ..
    Please help :)
  • #2 16309284
    sosarek
    Help: 9320
    Rate: 15532
    His model could also be written.
    SPDIF output is active in the decoder settings?
    Z
    Pka, Poznań, 60-850
  • #3 16309956
    MAMROCK
    Help: 5
    The Soundbar model is in the title of the post.
    I looked through the entire decoder menu - I can't find an option where to turn the audio on or off ...
  • #4 16310012
    sosarek
    Help: 9320
    Rate: 15532
    There is no such thing, except as I understand it you have connected the signal to the analog input of the soundbar - it will not work.
    Use the decoder SCART socket.
    Z
    Pka, Poznań, 60-850
  • #5 16310195
    Polon_us
    Help: 1184
    Rate: 1280
    Er, I think there's one more solution.
    The decoder has an S / PDIF Coax output, the so-called "electric" and the sound-bar has an optical input.
    The only way to do that is with an "electrical" digital to optical digital audio converter.
    Such as the picture below. No problem to buy.
    Please pay attention to the description of the converter sockets -> Coax IN - Optical Out - it is very important.
    A colleague will still need a typical CINCH cable and a TosLink optical cable.
  • #6 16311791
    MAMROCK
    Help: 5
    There is a cable because I bought it and I have it in my drawer :) but it does not work in the decoder-> soundbar configuration, but it works in the TV set -> soundbar (chinch output from TV and minijack input in the soundbar)
    And in the case of SCART, the outputs from the bundles end with chinchas and in Sonbar they are missing - so a grommet will be necessary, I think ...
  • #7 16311870
    KOCUREK1970
    Help: 3860
    Rate: 5488
    MAMROCK wrote:
    There is such a cable
    And he looks like this one ?:
    Because it is an optical cable on both sides - it differs only in the plug (I have one next to my computer and my soundbar).
    Because what you bought is probably an ordinary chinch - minijack - and not an optical cable (which a colleague asked about saucers ).
    Post # 5 explains it all - buy what is recommended in it (URGENTLY pay attention to I / O ports).
  • #8 16314736
    sosarek
    Help: 9320
    Rate: 15532
    MAMROCK wrote:
    in the case of SCART, the outputs from the bundles end in chinchas and in Sounbar they are not - so a grommet will be needed, I think ...
    You think right, buy a SCART-RCA adapter / converter, RCA-JACK cable and that's it.
    Z
    Pka, Poznań, 60-850
  • #9 16320807
    MAMROCK
    Help: 5
    I will probably do that tomorrow.
    I will write about the results.
    And by the way, to complicate people's lives ...
  • #10 16324030
    MAMROCK
    Help: 5
    And no signal on the SOUNDBAR ..
    Scart + minijack grommet = no sound ...
    Is there any HDMI signal splitter for other devices?
    It hits me already, because of the cables I have, I would pin 300 devices - and I can't 2 ... This ITI buys crap for NC + .. In the 21st century, no optical output? Colostrum ...
  • #11 16324032
    sosarek
    Help: 9320
    Rate: 15532
    What SCART, RCA adapter or SCART-RCA cable (and are you sure the outputs and not the signal input?).
    Z
    Pka, Poznań, 60-850
  • #12 16324955
    MAMROCK
    Help: 5
    So yes - I bought a SCART -> RCA cable. Then via RCA to Minijack and STILL NOT WORKING. I have already connected Audio IN and Audio Out to the grommet - no sound signal (the only hum when connecting the cables) ...
    I will try the "converter" from SPIDF to "optics" -
    All this fun is a nightmare ....
  • #13 16324979
  • Scart-to-RCA cable fails; seeking alternative connection
    #14 16325003
    MAMROCK
    Help: 5
    Okay .. My mistake
    Fix - I bought a EURO -> RCA4 cable.
    Tomorrow I will return this one and go to a professional shop and ask for what you write above. Some obscurity took me in discriminating RCA, SPIDF, cinch and all the rest :)
    Added after 6 [minutes]:
    So the fix - I bought it well.
    Euroconnector (Scart) to Cinch (RCA)
    In this configuration, the hell does not work ...
    There are other solutions - if they are ..
  • Verify Euro-RCA cable direction and adapter I/O ports
    #15 16325128
    KOCUREK1970
    Help: 3860
    Rate: 5488
    But how can you be sure that you have bought Z euro for chinche and not chincha for euro? - take a picture of it and post it here.
    And which RCAs do you connect the adapter to (describe it, take a photo)?
  • #16 16359135
    MAMROCK
    Help: 5
    It does not run on any cables. No sound in SW.
    I have to buy a "converter" but I'm afraid that I will throw money down the drain again ...
    Any more ideas?
  • #17 16359169
    KOCUREK1970
    Help: 3860
    Rate: 5488
    MAMROCK wrote:
    Any more ideas?
    Everything has already been described here.
  • #18 16974320
    MAMROCK
    Help: 5
    Unresolved problem ,,,,,,,,
  • #19 16974325
    KOCUREK1970
    Help: 3860
    Rate: 5488
  • #20 17249853
    MAMROCK
    Help: 5
    I did not solve the problem -
The discussion revolves around connecting the NC+ decoder (Model DB NCP-4740SF wifi Premiumbox +) to a Samsung Soundbar (HW-H430). The user faces challenges due to the decoder's audio output options (Dolby Digital via SPDIF and HDMI) not being compatible with the Soundbar's inputs (optical and minijack). Attempts to use an SPDIF to minijack cable were unsuccessful. Suggestions include using a digital to optical audio converter to connect the SPDIF output from the decoder to the optical input of the Soundbar. The user also explored using SCART connections but encountered further complications. Despite various attempts and recommendations, the user has not yet resolved the audio connection issue.
