Gorenje W6503 washing machine - how to set a Favorite Program?
alina_129 7152 2
  • #1 16596997
    alina_129
    Hello, despite the manual, I can't set my favorite program on the Gorenje W6503 Washing Machine.
    I am asking for help, because when the knob is turned to Favorite Program, only the word SEL appears and there is nothing you can do about it.
    greetings :)
  • #2 16599298
    MDD
    Help: 179
    Rate: 545
    You set eg Favorite program 1. It is SEL. You turn to the program to be remembered. And confirm by pressing buttons 6a + 7 together. The rest in the manual.
  • #3 17722972
    gregory8383
    Rate: 25
    Hello, I have an identical problem. maybe someone will help me.
    I am looking for a program in the washing machine gornje w7763i with a duration of about 1 hour and a temperature of 60 degrees. There is no. If there is such a time, the temperature is max. 40 degrees. And if the temperature is 60 degrees, again the time is at least 2 hours. 40 min.
    I called the hotline and the lady said that I have to program such a program for 60 minutes and 60 degrees. The question is how?
    I switch to my favorite program, the display shows SEL and nothing else can be set. The temperature and time buttons are disabled.
    I don't want to program my favorite program from the ones that are available. I want to create my own with time and temperature that suit me. Can anyone help me?
