Selecting the Most Reliable and Repairable 7kg Gorenje Washing Machine Model
Piotr147258 7275 5
  • #1 16696662
    Piotr147258
    Rate: 9
    I am asking for help in choosing a washing machine, first of all I want to find a washing machine which the producer has programmed as little as possible to spoil. After careful analysis of the forum, I came to the conclusion that the best choice would be Miele, but unfortunately it is too expensive for me, so I am looking for a cheaper alternative. The choice fell on the company Gorenje, because it is cheaper than Miele and not much bad here I read about this company, and even met with positive feedback.
    Apparently, only 7kg models have replaceable drum bearings, so I'll buy 7kg
    7kg models:
    Gorenje W7723 / I
    Gorenje W7723PL
    Gorenje W7503PL
    Gorenje W7443LA, W7543LR, W7543LO
    Which of these models will be the best in terms of reliability or possible self-repair later?
  • #2 16696690
    Lodxx
    Home appliances specialist
    Help: 105
    Rate: 245
    In my experience, the average life time of gorenje without failure 3-4 years, at this age I bring from Germany already faulty electronics often rains but the equipment is generally solidly made.
  • #3 16701087
    Piotr147258
    Rate: 9
    The Gorenje W7723 / I model has an inverter motor and the other models have a normal motor. Which motor will be better inverter or ordinary?
  • #4 16701663
    Lodxx
    Help: 105
    Rate: 245
    It depends on whether you want a quieter washing machine or not, the inverter motor is less noisy but because of the more emergency inverter needed for it, the average cost of the inverter plate is about PLN 500, the brush motor is a normal motor with a commutator which is louder but there are less elements to spoil it the engine itself is cheaper.
  • #5 16755650
    Piotr147258
    Rate: 9
    I bought a Gorenje W7723 / I washing machine
    Thank you for helping me buy :)
  • #6 16755682
    Lodxx
    Help: 105
    Rate: 245
    I hope that it will serve because it's nice washing machines but not very popular.
