Barton Falcon - Wiring Guide for Simultaneous Low and High Beam Functionality
ddamianekk18 5331 10
How can I wire the headlights so that the low beam stays on when the high beam is turned on?
Bridge the blue/white wire with the white wire at the low/high beam switch so both lights receive power at the same time [#16601316] Add a switch or disconnect option so you can return to normal operation when needed and stay within regulations [#16598796] Be aware that running both beams together increases the load, and the generator may not handle it well [#16598796] This was also described as a solution used after headlamp changes where the dipped beam must not switch off [#16601316]
  • #1 16597621
    ddamianekk18
    Rate: 49
    Hello, I mean what wires should be connected with each other so that after turning on the high beam, the low beam lights do not go out, but light up simultaneously.
    https://obrazki.elektroda.pl/5116838300_1498842722.jpg
    Staszek49
    Help: 228
    Rate: 1140
    You need to add a system that connects both lights, with the possibility of disconnecting them, so that it complies with the applicable regulations. I believe that the effects of such a solution may be meager, because the "generator" will not be able to handle such a load.
  • #3 16600864
    BANANvanDYK
    Help: 1167
    Rate: 2602
    The illumination of both filaments of the headlight bulbs is not favorable for reasons of durability. Besides, the law probably does not allow such work. This is only permissible when there are separate headlamps, one for the dipped beam and the other for the high beam.
  • #4 16601225
    Heinzek
    Help: 554
    Rate: 494
    ddamianekk18 wrote:
    after turning on the high beam, the low beam does not go out, only so that it lights up simultaneously.
    For what purpose? Do you install xenon?
    It is practically enough to combine blue / white with white in the area of the low / high beam switch.
  • #5 16601237
    milejow
    Help: 1563
    Rate: 5149
    And how will it turn on the low beam after bridging both cables?
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #6 16601247
    Heinzek
    Help: 554
    Rate: 494
    I think you mean the road only, because unfortunately this option will not be. Unless to use a "hidden" switch.
    The most important and so is the question of the need for such a solution, because I consider it unnecessary, probably for Chinese bi-xenon which will be illegal in this lamp anyway.
  • #7 16601272
    milejow
    Help: 1563
    Rate: 5149
    Heinzek wrote:
    I guess you mean the road itself,
    I wrote clearly what I mean. For the set, suggest also bridging the left and right directions.
    Działalność własna
  • #8 16601290
    ddamianekk18
    Rate: 49
    BANANvanDYK
    - But I have two separate headlights, not a two-filament bulb.
    Heinzek
    - I do not know what you woke up with these xenon and bi-xenonami but better not to speak anymore because you write BZDURY man, no one even mentioned xenon and you get off the Christmas tree and start a bottom topic.
    It is best, the easiest, logical and the first topic to solve
    Staszek49
    and it is one of the simplest sentences that I have completely forgotten
    I consider the topic exhausted,
    Staszek49
    Thank you for your help.
  • #9 16601316
    Heinzek
    Help: 554
    Rate: 494
    You asked a question:
    You got the answer:
    I have not met anyone who would turn on both lights at the same time on a scooter, but I gave a solution anyway.
    Such things were done in some cars after changing the lamps that required the dipped beam not to go out - mainly from H4 to bi-xenon.
    best regards :)
  • #10 16602344
    BANANvanDYK
    Help: 1167
    Rate: 2602
    I wonder what you write and what you suggest to us. The Chinese in this kennel have such "double" headlights, but with the low / high beam function on the left and right side of the lamp, they have two 18 / 18W or 25 / 25W S2 or HS1 double filament bulbs with reduced power. With the rest of the diagram you gave it follows. Only some Chinese cars have separate headlamps for low beam and high beam, most often those whose design is copied from Italian scooters. And in Italian there is something else used, for example Aprilia SR50 and Piaggio NRG Power have halogen bulbs (from what I remember) H8 35W with a plastic base and a plug housing (like typical HB3 cars), yet they do not glow together with the traffic light on.
  • #11 16604460
    ddamianekk18
    Rate: 49
    I consider the topic exhausted after the first reply from my colleague
    Staszek49
    Thank you all for your willingness to speak.
The discussion revolves around the wiring of the Barton Falcon to enable simultaneous operation of low and high beam headlights. Users express concerns about the legality and practicality of such modifications, noting that illuminating both beams may not be advisable due to durability issues and potential regulatory violations. Suggestions include using a system to connect both lights while allowing for disconnection to comply with regulations. Some participants mention that this setup is more common in vehicles with separate headlamps for each beam type. The conversation also touches on the use of bi-xenon systems and specific wiring configurations, with a focus on the implications of modifying headlight functionality in scooters and motorcycles.
