Becker ready5 BE B60: Unlocking & Automap Upload Issues - Memory Card Solutions
krecik10 7074 3
  • #1 16597831
    krecik10
    Rate: 56
    Please info if anyone had the opportunity to unlock this model, I have a problem with uploading the automap, as I mark the Becker add-on, the selection of the automap appears in the lower left corner, but when I press, the navigation freezes and the red square hangs on the automapa's stamp. I upload everything to the memory card.
  • #2 16598298
    Gienek
    Level 37  
    Help: 393
    Rate: 352
    Badly loaded automap. When uploading to a memory card (not via navigation), select the appropriate option (Becker 5.0). Then there will be no trouble.
  • #3 16598610
    krecik10
    Rate: 56
    Unfortunately, there is nowhere to choose the Becker 5.0 add-on ..., there is becker ready 45. becker ready 50 etc. in the third line as it gives, the automap abbreviation does not appear at all, only when I mark becker active 5 ce lmu etc. (i.e. the second Becker's row) then the shortcut shows but the navigation hangs after clicking on the automap shortcut.
  • #4 16604850
    krecik10
    Rate: 56
    The navigation done on the panel with shortcuts was the problem mentioned above.
