Navia NV45 - AutoMapa 6.25 Route Vanishes: Map, Voice Prompts Issues & Speed Display
przemo6996 3801 3
  • #1 17512584
    przemo6996
    Hello. I tried to upload different versions and the problem was the same. Navigation normally starts, calculates the route, navigates but after a few minutes the map disappears, there is an arrow and a blank field, no voice prompts, the speed is displayed correctly.
    wojtek1234321
    Level 36  
    Help: 306
    Rate: 1130
    AutoMapa 6.25 legal or cracked? If this is the version with a crack, then do not be surprised, in this version the crack does not work anymore and these are the symptoms. It is illegal to use such programs.
  • #3 17663567
    krysztek
    This version is not terrible, it has bugs. The patch has already come out on 24/12/2018, wait for it to be downloaded and update yourself.
  • #4 17663944
    jajacekpl
    Help: 65
    Rate: 268
    Give a screenshot of this "blank field."
    The AM requirements have long exceeded the capabilities of the Nv45, so maybe the hardware is just not doing it.
    If you have AM on SD, then transfer to the device (if it does not fit, leave the MAPS folder on the card
