Modecom Navigation Issue: Automapa Not Launching from GPS Menu after Update, Memory & Fix
Pieter1337 6444 3
  • #1 16978735
    Pieter1337
    I have modecom navigation. After trying to update the automapa to a newer one, I had to remove the older one (not enough memory), And when I installed the map, I restarted the device on the screen after clicking on GPS, the AUTOMAP selection window does not start. When I enter through windows, the automap opens normally.
    How to fix it that it would be possible to turn on the Auto map once only by entering the initial screen and clicking GPS?
  • #2 16978897
    koala106
    Help: 471
    Rate: 1240
    Set the path in the settings.
  • #3 16978907
    jajacekpl
    Help: 65
    Rate: 268
    Just don't ask how it's done, as you might not even look at the ModeCom manual ...
  • #4 16980148
    Pieter1337
    I just couldn't find the path settings.
