Becker BE B60 Navigation: Issues with AutoMapa and Becker Navigation Selection
JanQ48 6621 7
  • #1 16286135
    JanQ48
    Rate: 9
    I installed the automapa on the SD memory card.
    After starting the navigation, a window with the word Becker is displayed and I have two icons to choose from: AutoMapa EU, Navigation Becker.
    When I select one of the icons, it is highlighted, however, it does not go further to AutoMapa navigation or Becker navigation.
    To better illustrate the problem, I enclose a photo
    Do you have any idea for that?
    Please help...
    • Becker BE B60 Navigation: Issues with AutoMapa and Becker Navigation Selection Becker be b60.jpg (36.8 KB) You must be logged in to download this attachment.
  • #2 16286443
    11111olo
    Rate: 795
    Are you sure that SD cards can be turned on AM?
  • #3 16292522
    jajacekpl
    Help: 65
    Rate: 268
    Did you choose any add-ons when installing Automapa? If so, what?
    You had this screen before (unlocked), or did it appear after installing AM with the add-on?
    Because this model should pull AM (800MHz and 128 RAM according to the manufacturer)
  • #4 19041830
    woras328
    I need help. I have the same problem, it appears to me after installing AM on the SD card with the Becker Active.5 CE add-on, there are shortcuts as in the picture in the first post and after clicking on the automap, only a red frame appears.
  • #5 19041985
    Gienek
    Level 37  
    Help: 393
    Rate: 352
    Have you installed AutoMapa to the SD card in the reader? If so, describe how you did it.
  • #6 19042091
    woras328
    Through a card reader. I started the installation, I chose the advanced installation-> memory card-> windows CE-> lector selection-> Becker Active.5 CE add-on because the other two do not work-> installation of the entire map and install.
    Map version 6.24_2006 from June 2020
  • #7 19042103
    Gienek
    Level 37  
    Help: 393
    Rate: 352
    And what is the capacity of the SD card? Because it can't be too big (2-4GB)
  • #8 19042178
    woras328
    2GB SanDisk after FAT32 format
    Edit:
    I was able to understand the topic. It was enough to install with the addition of Nokia500 according to this subject
✨ The discussion revolves around issues encountered when installing AutoMapa on a Becker BE B60 navigation device. Users report that after installation, the navigation options (AutoMapa EU and Navigation Becker) do not proceed beyond the selection screen. Several users inquire about the installation process, specifically whether the SD card was formatted correctly and if the appropriate add-ons were selected during installation. One user successfully resolved the issue by installing with the Nokia500 add-on. The importance of using a compatible SD card size (2-4GB) is also highlighted.
