How to connect AUX to Blaupunkt RD4 N1 MPS?
kbos2 56097 6
  • #1 16994599
    kbos2
    My radio is Blaupunkt RD4 D2 N2.
    In my Peugeot 407 sw from 2005 I wanted to connect the AUX input to be able to listen to music, e.g. from a phone or an mp3 player.
    It was supposed to be fairly simple. Unfortunately, the situation was a bit too much for me.
    I bought an AUX cable like in the picture:
    I connected to the input on the back of the radio and wanted to activate it using the diagnostic interface. Unfortunately, when I wanted to turn on the AUX1 connector via the diagbox, only the message "bad programming" popped up, the second AUX is still set to the external mute and it cannot be changed. From the level of Peugeot, the planet did not see such an option at all.
    I read a bit on the Internet and it comes out that my radio is connected to the second AUX output by a connector from the bluetooth installation.
    Unfortunately, I can't see bluetooth anywhere. You can see the wires themselves.
    I thought that you can connect to the wires from the AUX 2 output. I found a schematic on the internet
    And here's the question - if I connect the cables from AUX 1 to AUX 2, black to pin 8, red to pin 4 and white to pin 10, will it make sense?
  • #2 16994667
    LWD11
    Help: 223
    Rate: 486
    If there is no bt, try to connect to this active AUX, just check what you have on the mute. Sometimes diagbox also makes such tricks on me, then I do the global test again and the configuration is successful.
  • #3 16995505
    kbos2
    The point is that I connected normally to this free AUX and tried to activate it in various ways. Unfortunately, to no avail.
  • #4 18251850
    mpawlok
    Rate: 25
    And what? Have you solved the problem? If so, share the solution, of course if you can, and if not, there are two of us.
    Best of all, with the AUX 1 input I can do everything, set every option, but unfortunately it is occupied by bluetooth, and when I try to change any of the AUX 2, the message "wrong set-up" pops up.
  • #5 18252116
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Some versions of the RD4 only have 1 AUX input.
  • #6 18259471
    mpawlok
    Rate: 25
    You didn't console me. The pins on the radio are supposed to be blind?
  • #7 18409337
    Tomica Zajkov
    Rate: 26
    can this radio be turned on the desk
The discussion revolves around connecting an AUX input to a Blaupunkt RD4 D2 N2 radio installed in a 2005 Peugeot 407 SW. The user attempted to connect an AUX cable to the radio's input but encountered issues when trying to activate it via the diagnostic interface (diagbox), receiving a "bad programming" message. Other participants suggested checking the mute settings and performing a global test to resolve configuration issues. It was noted that some RD4 models may only support one AUX input, and there were questions about the radio's pin configuration and Bluetooth connectivity, which could affect AUX functionality.
