Installing AUX on Original Blaupunkt RD4 N1 Radio in Peugeot 207 2007: Guidance Needed
fuspepro 20226 6
  • #1 16671912
    fuspepro
    Rate: 9
    Hello, this is edit the previous topic.
    I have a Peugeot 207 car from 2007. It has the original radio - Blaupunkt RD4 N1 -.
    I read a lot of topics on the forum, but I did not find a satisfactory answer.
    A lot of people wrote to order such a cable http://allegro.pl/zlacze-aux-1-5m-rd4-peugeot-rd4-207-307-407-607-80-i6510930895.html. And connect it instead of the CD stations on the radio in the back.
    I also found this video - https://www.youtube.com/watch?v=QROwHI7-h8s&list=WL&index=4 and this product that seems credible BUT I can not find where it can be ordered and this is probably not possible on this site. (besides, it will probably amount to over PLN 150 + shipment from abroad, and I prefer a cheaper solution). -product http://www.connects2.co.uk/Product/ProductItem/CTVPGX011.
  • #2 16673743
    malimaro
    Rate: 159
    It's best to buy the original and after the trouble
  • #3 16673828
    fuspepro
    Rate: 9
    We have not understood, I want to buy a non-original radio for peugeot because in ORIGINAL there is no AUX input. And how do I buy not original from AUX, will I be able to control the radio and computer with this joystick on the steering wheel?
  • #4 16674467
    malimaro
    Rate: 159
    probably not unless you have a lot of knowledge about electronics
  • #5 16675857
    fuspepro
    Rate: 9
    EDIT: THEME
  • #6 16675886
    SZYMON BYDGOSZCZ
    Help: 340
    Rate: 1709
    Then activate them and + AUX wire after the robot.
  • #7 16676060
    fuspepro
    Rate: 9
    I am looking for people who have had a similar problem. And answers in the style - "just do it" do not help if you do not explain in detail what to do. Is the cable alone enough?
The discussion revolves around installing an AUX input on the original Blaupunkt RD4 N1 radio in a 2007 Peugeot 207. The user seeks guidance on connecting an AUX cable, having found various resources, including a specific cable link and a product from Connects2. Responses indicate that while using a non-original radio may not allow control via the steering wheel joystick, activating the AUX input is possible with the right wiring. However, detailed instructions are requested, as the user is uncertain if the cable alone suffices for installation.
