Lenovo ideapad 100S-14IBR - the laptop stops at the word Lenovo
7113 10
How can I get a Lenovo IdeaPad 100S-14IBR that stops at the Lenovo logo to boot from USB or start recovery again?
Try a CMOS reset first, because a corrupted firmware state can block normal startup [#16369831] Recreate the installer on a USB stick with Rufus, since Lenovo machines may not boot reliably from USBs made with other tools [#16369973] In BIOS, switch Boot Mode to Legacy Support, set Boot Priority to Legacy First, enable USB Boot, and disable Secure Boot; also use a USB 2.0 port and, if possible, a USB drive made with Windows from another stick [#16371585] If it still freezes at the Lenovo logo, check whether the eMMC/disk is visible in BIOS and read its SMART data, because a damaged drive can also cause a hang on the logo [#16370143][#16371679]
  • #1 16369727
  • #2 16369831
    miecho18
    IT specialist
    Help: 3087
    Rate: 2777
    krystianq1984 wrote:
    What else can be done
    CMOS reset for example.
  • #3 16369973
  • #4 16370143
    grubas
    Level 40  
    Help: 647
    Rate: 553
    Check the disk. In Samsung, if the disk is damaged, it also hangs on the Samsung logo.
  • #5 16370763
    lisek
    Service technician RTV
    Help: 6350
    Rate: 6880
    Can you enter Bios?
    Do you have the lenovo logo for the whole (full) screen?
    The fan runs, then stops ..?
    ps
    Lenovo Ideapad 100s-14IBR Motherboard 2GB / 64GB
    * Celeron N3050 1.6GHz, LA-B921P platform
    * P / N: 5B20K69445
    Lenovo ideapad 100S-14IBR - the laptop stops at the word Lenovo Lenovo ideapad 100S-14IBR - the laptop stops at the word Lenovo
  • #6 16370986
  • #7 16370991
    lisek
    Help: 6350
    Rate: 6880
    because it is laptop under warranty So I can't undress it
    I don't know what are you waiting for?
  • #8 16370997
  • #9 16371030
    lisek
    Help: 6350
    Rate: 6880
    a laptop with a warranty is a client's laptop not mine
    Give it back, let the owner_customer do the rest
    - unless it's from the "night shop" and no papers
    You can do .... a disservice. Link
  • #10 16371585
  • #11 16371679
    RADU23
    Help: 2428
    Rate: 1732
    The disk cannot be checked because it is built into the motherboard
    What does it mean?
    First go to the BIOS and say if the disk is visible there?
    If so, include its SMART with MHDD =>
    http://www.nirvanowiec.republika.pl/MHDD.iso
The Lenovo Ideapad 100S-14IBR is experiencing boot issues, halting at the Lenovo logo. Attempts to restore the system via recovery options and boot from USB drives (Windows 7, 10, and Hiren's Boot) have been unsuccessful. Suggestions include performing a CMOS reset, creating a bootable USB with Rufus, checking BIOS settings, and ensuring the USB drive is compatible with Legacy mode. The user is unable to disassemble the laptop due to warranty restrictions and has confirmed that the disk is integrated into the motherboard, complicating diagnostics.
