Loss of TVP1 and TVP2 Channels on Terrestrial TV After Storm - Antenna and Power Supply Checked
kajamark 14271 7
  • #1 16604295
    kajamark
    Rate: 64
    I have a problem with the reception of TVP1, TVP2 programs the rest of the programs is ok.
    It happened after the storm. Previously, the power supply and antenna cable was removed.
  • #2 16604352
    LeDy
    Help: 1992
    Rate: 2940
    This is not possible because there are more programs on a given MUX.
    What do you receive?
  • #3 16604362
    kajamark
    Rate: 64
    MUX3 does not work, I just gave an example of TVP1
  • #4 16604380
    LeDy
    Help: 1992
    Rate: 2940
    What you did, you checked, where did you get from, what, what parameters on the other signal?
  • #5 16604405
    kajamark
    Rate: 64
    Others pick up correctly the day before it was all ok.
  • #6 16604411
    goldi74
    Help: 1367
    Rate: 1539
    Maybe it's MUX's fault and not TV? Do these channels operate with neighbors?
  • #7 16604513
    _kli_
    Help: 762
    Rate: 1040
    Maybe the wind turned your antenna? On which transmitter is it directed and on which channel you have tuned mux-3 in the receiver? (Śrem and Piątkowo - k.27, Żółwieniec - k.36)
  • #8 16744767
    kajamark
    Rate: 64
    After replacing the antenna amplifier, the TV started to receive all the programs. Thank you for the tips. I am closing the subject.
The user reported a loss of reception for TVP1 and TVP2 channels after a storm, while other channels remained unaffected. Initial responses suggested checking the MUX settings and the antenna's alignment, as well as confirming the operational status of the MUX. The user later indicated that the issue was resolved by replacing the antenna amplifier, which restored reception for all programs.
