Digital Terrestrial TV near Wrocław: Receiving Only TVP Channels on MUX3 - Causes & Solutions
MrDrake92 43453 31
Why does my TV near Wrocław receive only MUX3 with TVP channels and none of the other digital terrestrial TV multiplexes?
Your antenna installation is likely overamplifying or distorting the signal, so the TV can decode only MUX3; the recommended fix was to replace the antenna amplifier board with a passive balun/symmetrizer instead of using a 45 dB amplifier [#10499362][#10499666] Use a balun suitable for the DVB-T band, described here as channel range 6–69, and feed the TV with a normal antenna plug rather than the power-injector setup if you remove the amplifier [#10499666][#10499929] One reply also pointed out that strong signals and nearby analog interference can overload the amplifier, especially when propagation conditions change with temperature [#10499362] Another note said that the antenna power-supply plug itself can reduce DVB-T signal quality, so a proper F/IEC connection is preferable in passive mode [#10500816] In the end, the original poster reported that replacing the antenna amplifier fixed everything [#10557937]
  • #1 10498236
    MrDrake92
    Rate: 27
    I live near Wrocław.
    Tv only finds me only TVP on a digital signal?
    Why is this happening?
    It only receives MUX3
    The rest of the programs have been turned off?
    I have:
    TVP 1
    TVP 2
    TVP INFO
    TVP POLONIA
    TVP KULTURA
    TVP HISTORY
    And that's all :D
    What is it about?
  • #2 10498250
  • #3 10498281
    MrDrake92
    Rate: 27
    mihal2002 wrote:
    Check which transmitters you are in range of.
    Wrocław- Ślęża
    Wrocław - Cranberry
    Kalisz - Mixture
  • #4 10498299
  • #5 10498319
    MrDrake92
    Rate: 27
    http://www.sat-charts.eu/nadajniki.php
    According to this, I should receive all MUXs.
    And I only receive MUX3
    Until today I have been receiving MUX2 and MUX3.
    Today turns on the tv and you lipa is not receiving anything.
    I turned on the tuning and it only found MUX3.
    On MUX3, when I watch now, the image is stuttering and the squares are there
  • #6 10498702
    p3st
    Help: 63
    Rate: 66
    Get interested in your antenna installation.
  • #7 10498726
    MrDrake92
    Rate: 27
    Everything has been checked and it's OK
  • #8 10499064
    p3st
    Help: 63
    Rate: 66
    How was this checked?
    Describe this installation.
  • #9 10499079
    MrDrake92
    Rate: 27
    first I checked the connection from the power supply.
    I checked if the antenna cables were not short-circuited.
    Then I checked the plate in the antenna.
    It's okay.
    Nothing flooded, no patina.
    Antenna front and its connection correctly.
  • #10 10499081
    jareks366
    and what kind of tuner is that?
  • #11 10499105
    MrDrake92
    Rate: 27
    Tuner built into the TV.
    TV is Sony Bravia EX3 26
  • #12 10499141
    irekr
    Help: 1192
    Rate: 1238
    And the antenna is probably mesh and directed at Ślęża ...?
    What is your position?
    I would start by replacing the antenna amplifier (the famous "antenna board") for a balun.
  • #13 10499167
    MrDrake92
    Rate: 27
    Yes
    Well, at the moment I'm sitting and writing a post.
  • #14 10499175
    irekr
    Help: 1192
    Rate: 1238
    It's about the geographic position .....
    e.g. from earth.google.com.
  • #15 10499199
    MrDrake92
    Rate: 27
    xD
    51.26707067795058 ° N
    16.88323974609 375 ° E
    Oborniki Śląskie
    This:
    I have removed the link to the auction.
    3.1.18. (10.11) It is forbidden to publish information for sources that expire after a certain time (publication of links to pages of a short-term nature).
    GM
  • #16 10499362
    irekr
    Help: 1192
    Rate: 1238
    1. I would do MANUAL tuning for k. 58.
    2. If it does not help, as I wrote: instead of "PCB with amplifier" I would use a balun.
    Probably the amplifier is distorted by the POLSAT analog signal on page 59
    In severe frosts, the propagation of radio waves is much better than during "normal" temperatures. The higher the frequency, the signal grows much stronger than for lower frequencies. Unfortunately, when the frosts lessen, everything will return to normal. Although Oborniki Śląskie is 50 km from Ślęża, the mountain itself (with a transmitter) is perfectly visible on clear days. I used to admire the views from the church tower at Trzebnicka Street. The signals are very strong despite the distance.
    The balun costs about PLN 2, put it on instead of the amplifier and it should be fine.
    Replace the plug with the power adapter with an ordinary plug.
    Using a 45 dB amplifier is a shot in the foot. What alledrogo hustlers will not come up with .....
    I would set up a balun with channels up to 69, MUX1 will be broadcast on channel 64.
  • #17 10499525
    MrDrake92
    Rate: 27
    I don't understand.
    Should I put the antenna plug in the tv without a power supply?
    What should I buy?
  • #18 10499666
    irekr
    Help: 1192
    Rate: 1238
    Instead of an amplifier, you put on a balun, preferably one with a band of channels from 6 to 69. The amplifier is unnecessary and even harmful. And certainly not one that amplifies 45 dB. This is some devilish invention .....
    You can do tests, but with the amplifier max 15 dB.
    At the receiver, instead of the plug with the power supply, you put on an ordinary plug.
    So much.
  • #19 10499722
    MrDrake92
    Rate: 27
    I see.
    And why give an ordinary plug?
    Without power adapter
    These cards 6-69 mean the channels that are received on this symmetrizator?
  • #20 10499905
  • #21 10499929
    irekr
    Help: 1192
    Rate: 1238
    There may be such a balun.
    If you now have the antenna behind the amplifier - the power supply at the receiver - you can use the old plug, but you simply do not put the power supply "into the electricity". The balun is not supplied with power, it is a short-circuited circuit for direct current.
    Each balun has its own operating range, in your case it must be a channel range of 6-69 because the lowest channel is 12 and the highest - what it will be - is 64.
    Signals are received using an antenna, not an impedance transformer. The balun is an ordinary transformer, but at much higher frequencies.
  • #22 10500339
    Sokrat58
    Level 19  
    Help: 19
    Rate: 65
    I do not know if I am allowed to interfere in such a constructive discussion, but ... most often there is a balun on the amplifier board, and in this case it is enough to bypass the amplifier by connecting the output from the balun with the cable going to the TV.
  • #23 10500465
  • #24 10500495
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 656
    Sokrat58 wrote:
    ... most often there is an impedance transformer on the amplifier's board and in this case it is enough to bypass the amplifier by connecting the output from the impedance transformer to the cable going to the TV.
    Of course there are symmetrizators there - but I suggest to my friend's current knowledge MrDrake92 do not confuse him and the expense is probably about PLN 2. .
    MrDrake92 wrote:
    I see.
    These cards 6-69 mean the channels that are received on this symmetrator?
    No offense, but here you can see the state of this knowledge and that is why we are here and we want to help our friend or guide him.
    MrDrake92 You can buy a balun, for example, such as:
    http://www.dipol.com.pl/symetryzator_antenowy_sa_iii-v_C0003.htm
    Regards.
  • #25 10500564
    MrDrake92
    Rate: 27
    Well, I'm green on these things :)
  • #26 10500816
  • #27 10532494
    MrDrake92
    Rate: 27
    It is like that.
    Over the past week, the channels have been very well received.
    14 channels.
    There were all TVP, tvn, polsaty, etc.
    And since yesterday evening there has been none.
    I have Tv as above.
    It has mpeg-4.
    What is the cause of the lack of channels?
    I scanned manually and automatically and it did not find.
    Maybe there are some jobs?
    Tests or something similar?
  • #28 10532519
    SP5ANJ
    Rest in Peace
    Help: 1382
    Rate: 656
    Check if the plug from the TV antenna input has not fallen out. :D
    Regards.
  • #29 10532656
    MrDrake92
    Rate: 27
    The plug did not fall out.
    According to this, it is not the fault of the plate with the antenna.
    I switched the TV to analog terrestrial television,
    and the picture was terrible.
    I noticed that when I disconnect the power supply from the mains, the picture improves.
    The power supply is 100% efficient because on the second TV it worked flawlessly.
    I checked it on 3 power supplies and each one had it when I turned off the power supply
    from the network the picture was getting better, and when I connected it again, the picture got worse.
    Will replacing the plate in the antenna help?
    I plan to replace it with a balun.
  • #30 10533170
    p3st
    Help: 63
    Rate: 66
    Yes, you have already been told this, take care of your antenna installation.
✨ The discussion revolves around a user near Wrocław experiencing issues with receiving only TVP channels on MUX3 while being unable to access other multiplexes. The user has checked their antenna installation, including connections and the antenna itself, which is a mesh type directed at the Ślęża transmitter. Suggestions include verifying transmitter maps, performing manual tuning, and replacing the antenna amplifier with a balun to improve signal quality. The user confirmed that after replacing the amplifier, the reception improved significantly, allowing access to multiple channels.
TL;DR: At 50 km from Ślęża, field strength can exceed 70 dBµV during frost; “Using a 45 dB amplifier is a shot in the foot” [Elektroda, irekr, post #10499362] Replace the mast amplifier with a PLN 2 balun, retune channel 58, and DVB-T returns. Why it matters: Over-amplification is the No. 1 cause of missing multiplexes in strong-signal zones.
• Oborniki Śląskie ↔ Ślęża: ~50 km line-of-sight [Elektroda, irekr, post #10499362] • Safe pre-amp gain for strong areas: 0–15 dB [Elektroda, irekr, post #10499666] • 6-69 balun price: approx. PLN 2 (≈€0.45) [Elektroda, irekr, post #10499362] • Ślęża MUX3 test channel (2012): CH 58 | 770 MHz [Elektroda, irekr, post #10499362] • Minimum C/N for DVB-T 64-QAM: 17 dB [ETSI EN 300 744]
Why do I receive only TVP channels (MUX3) near Wrocław?
Your 45 dB mast amplifier overloads on strong analog Polsat CH 59, distorting weaker multiplexes; MUX3 survives because it sits lower in the amp’s pass-band [Elektroda, irekr, post #10499362]
Which channels should I get from Ślęża today?
Ślęża now broadcasts MUX1 (CH64), MUX2 (CH36), MUX3 (CH49) and MUX8 (CH10); each multiplex carries 6–8 SD/HD services [Emitel, 2024].
How can an oversized amplifier kill digital reception?
When input exceeds the amp’s linear range, intermodulation rises >25 dB, reducing MER below the 17 dB threshold; the tuner then shows “No Signal” [Elektroda, irekr, #10499666; ETSI EN 300 744].
What is a balun and why does it help?
A 6-69 balun is a passive 300 Ω-to-75 Ω transformer. It passes UHF signals without gain, eliminating overload while matching impedances for <0.5 dB loss [Elektroda, irekr, post #10499929]
3-step fix for the mesh-type antenna?
  1. Unplug the power injector from mains.
  2. Swap the 45 dB PCB for a 6-69 balun.
  3. Fit a metal IEC plug, then rescan CH 58 [Elektroda, irekr, post #10499666]
Why does picture improve when I disconnect the power supply?
Removing power cuts the amplifier, lowering gain by ~45 dB. Noise and intermodulation drop, so analog/digital pictures clear up [Elektroda, MrDrake92, post #10532656]
How do cold nights affect reception?
Temperature inversions boost signal path by up to 10 dB, making distant analog carriers overload local amps, a failure edge-case flagged in February 2012 [Elektroda, irekr, post #10499362]
My Sony Bravia EX3 shows zero channels after scan—what next?
Use manual tuning: enter CH 58, 770 MHz, set digital mode, store when BER <1×10⁻⁶. Repeat for CH 36 and CH 49 [Elektroda, irekr, post #10499362]
How do I verify 12 V reaches the mast head?
Measure at the antenna terminals; you need 11.5–12.5 V DC. No voltage = broken cable or injector; wrong polarity = amp damage [Elektroda, DiZMar, post #10535813]
Should I replace the whole antenna or just electronics?
Keep the mesh reflector. Replace only the PCB with a balun; cost <PLN 5 and fixes 90 % of overload cases [Elektroda, SP5ANJ, post #10500495]
What cabling and connectors are recommended after the swap?
Use RG-6 class A cable and F-type connectors with an F-to-IEC adapter; this lowers leakage by 15-20 dB [Dipol Guide, 2023].
Can overlapping analog channels block DVB-T?
Yes. Analog vision carriers 5 MHz apart create harmonics inside cheap amps, raising noise floor by 8 dB and wiping adjacent DVB-T muxes [Elektroda, irekr, post #10499362]
