ELM327 OBD USB Interface: Windows 10 64-bit Installation Guide, Drivers v.2.12.28 & Signature Check
jat 116169 4
  • #1 17375737
    jat
    Rate: 8
    Hey!
    I see on many posts that you have problems installing the OBD interface based on ELM327 on USB. I also fought with Windows 10 64-bit and managed to find a solution, so I share it. I hope someone will need it :)
    Important information that the drivers can be uploaded, you need to turn off the signature check for a moment, eg in accordance with this manual:
    Installing digitally unsigned drivers
    Then we install these drivers:
    ELM327 drivers v.2.12.28
    in the standard way. If someone did not know how, then write.
    Information for wary people, the source of drivers comes from the percentage page:
    FTDI Chip
    you can compare that binary files have not been counterfeit.
    Good luck!
  • #2 17592447
    jat
    Rate: 8
    I get questions about step two, or how to install drivers after unpacking?
    Drivers do not have any installer, you have to carry out the procedure manually. For this purpose:
    - we open the Device Manager from the start menu
    - after connecting the interface, an unknown device should appear on the list (the names may be different, depending on the model)
    - we click them twice
    - on the second tab of the Driver, click Update Driver
    - we choose manual installation and indicate the directory to which we unpacked the drivers downloaded from the forum
    - they should be installed
    Sometimes an additional, unknown device may appear after the installation, then the procedure must be repeated.
  • #3 17592802
    lukas285285
    Rate: 12
    And how to configure this cable before and after it?
    I have elm 327 1.5 cable and are these rudders working with him?
  • #4 17594510
    jat
    Rate: 8
    Once you have installed the drivers, immediately see the device manager on which port it operates - there should be information, eg COM4. You select this port from the level of the OBD software. The software is a whole bunch, probably with a cable you also got something in the set.
  • #5 17594835
    lukas285285
    Rate: 12
    From the level of programming, i.e.
    Added after 55 [second]:
    You have a program for bmw e 90 and installation instructions for wines 10
