No Picture & Video Card Fan Max Speed: Metro 2033 Redux, MSI N550GTX-Ti, Chieftec GPS 400AA 101A
Recker14 9078 13
What could cause a PC to reset during a game, then boot with no display and the graphics card fan running at full speed?
The most likely cause is a damaged or burnt ATX 12V CPU power plug/connection, which can stop the motherboard from starting and leave the GPU fan at full speed [#16607173][#16607178][#16607234] Check the motherboard socket and the PSU connector for heat damage, and do not keep using that power supply until you measure its voltages with a meter [#16607227][#16607234] If you have a spare plug and the skills, you can replace or resolder the connector and insulate it well, then make sure it is pushed in firmly [#16607400] If the PSU caused an overvoltage, the graphics card and especially the motherboard may also be damaged [#16607227] After the hardware is fixed or replaced, load BIOS defaults or the last known good settings and verify the date and time [#16607386]
  • #1 16607131
    Recker14
    Hello guys
    I got out of bed and started the computer. I wanted to play my favorite game "Metro 2033 Redux", so I click on the icon, the game is loading and I was about to click "Continue" and here the computer reset (I had an afterburner for temperature control and a bit changed the work of the vet). After the reset, there is no image and the fan is walking like an F-16 jet. She worked at an average of 70 ° C.
    The steps I took are: blow everything with compressed air, take apart the power supply, clean it and check the capacitors, remove the graphics card cooling to smell the burn and look at the card in general. Anyone have any idea what hurts him?
    Unit Specifications:
    Graphics: Msi n550gtx-ti
    Power supply: chieftec gps 400aa 101 a
    Processor: Intel core 2 quad q6600
    Ram: Patriot pdc24g6400llk ddr2 800Mhz (2x2gb)
    Motherboard: Gigabyte Ga-965p-ds4 rev. 1.0 Bios the newest for this board
  • #2 16607149
    badboy84
    Help: 1198
    Rate: 1488
    Graphics card to be checked in another computer, power supply voltage to be measured with a meter. Is it in the speaker housing? Does it make any sounds? Did you overclock your CPU or graphics card?
  • #3 16607164
    Recker14
    The motherboard has a built-in speaker, but it does not squeak or the graphics card drowns it out. It was done on this and that, but that the machine has been working on factory timings for several months, but I found his suspect, namely the ATX 12V 2x plug has two pins as if burnt No Picture & Video Card Fan Max Speed: Metro 2033 Redux, MSI N550GTX-Ti, Chieftec GPS 400AA 101A No Picture & Video Card Fan Max Speed: Metro 2033 Redux, MSI N550GTX-Ti, Chieftec GPS 400AA 101A
  • #4 16607173
    badboy84
    Help: 1198
    Rate: 1488
    It's a fact, it doesn't look very good. If you have any old broken power supply, I would be tempted to replace this plug. Do not use this power supply with this plug anymore, maybe you have a replacement power supply? What does the socket on the motherboard look like?
  • #5 16607174
    safbot1st
    Help: 2719
    Rate: 1585
    Like nothing.
  • #6 16607178
    badboy84
    Help: 1198
    Rate: 1488
    The problem here is the power supply to the CPU, the motherboard won't start unless the CPU starts. I would exclude the graphics card for now.
  • #7 16607220
    Recker14
    So it could be this plug? Do you suggest buying a new power supply or transplanting the tip because I have one?
  • #8 16607227
    safbot1st
    Help: 2719
    Rate: 1585
    I do not know what the Author was up to the GPU rotation, but one could pull the other.
    Of course, I did not read that the photo shows the ATX plug, not PEG.
    If the overvoltage came from the GPU it could damage the GPU and the board.
    If not, you must take into account damage to the motherboard.
    First, measure the voltage from the power supply (the guide is available on the forum) by firing it briefly. If in doubt, do not connect this PSU at all.
    Added after 32 [seconds]:
    As I wrote, the motherboard probably burned out.
  • #9 16607234
    badboy84
    Help: 1198
    Rate: 1488
    At 85%, it is the cause of failure, if you have such a plug and minimum manual skills, you can replace it. Insulate the joints well. Start the power supply "briefly" and check the voltage with a tester if you have one. Nothing needed to burn, maybe it's just a lack of good contact. It is worth checking the socket on the motherboard, it can gently clean the pins to avoid another failure.
  • #10 16607365
    Recker14
    The plug was to blame, but there is one problem, I do not know what to do next No Picture & Video Card Fan Max Speed: Metro 2033 Redux, MSI N550GTX-Ti, Chieftec GPS 400AA 101A
  • #11 16607386
    badboy84
    Help: 1198
    Rate: 1488
    Restore default settings, or select 2 "Last known ...", check the date and time, save the settings and it should be OK.
  • #12 16607390
    Recker14
    And whether to solder these cables now? Can I play now?
  • #13 16607400
    badboy84
    Help: 1198
    Rate: 1488
    If you solder, it will be a more secure connection, but if they are well bolted and insulated, it shouldn't be a problem. Push the plugs firmly in place so that history does not repeat itself.
  • #14 16607424
    Recker14
    Thank you for your help! :)
The user experienced a computer reset while playing "Metro 2033 Redux," resulting in no display and a graphics card fan running at maximum speed. Initial troubleshooting included cleaning components and inspecting the power supply and graphics card. Responses suggested checking the graphics card in another system, measuring power supply voltage, and examining the ATX 12V plug, which showed signs of burning. Recommendations included replacing the damaged plug or power supply, ensuring secure connections, and restoring default BIOS settings. The user confirmed the plug was the issue and inquired about soldering cables for a secure connection.
