I advise everyone not to buy a scythe, in truth, the engine is good, but anti-vibration - reducing vibrations to a minimum level, the engine handle for the fight is a complete grit is the only biggest problem with the rotating engine
And I have a DEMON for 3 years and I am very happy and I use it to mow everything, even "thick brushwood" and finger-thick sticks. I do not spare her because I do not feel sorry, it will warm up a little and immediately gas to the maximum. So far, I only had to adjust the carburetor a few times because it likes to move, and besides, for such money, I would probably not get anything better. You also have to be careful with this handle that fixes the arms, the original threads are easy to make, but of course there is a way - a longer screw and nut on it.
He bins it a couple of times a year on a plot of land with a total area of about 0.4ha, multiply it, my friend, by 3 years and at least 4 times each year. In addition, I have a piece of field at the end of which there is a pond and a drainage ditch, various bushes and willows grow there, I put a shield and ... it's nice to "cut" such small trees Maybe I just came across a relatively successful model. Regards KuReK93
I mean exactly this contraption after half a year of mowing, the rubber inside develops and problems begin after two years I have to set up every tank something changes
To view the material on this forum you must be logged in.
Create an account, log in here and be active on the forum — ads won't appear. Earn points for registering and replying.
